Starts and Runs, Won't Start, Starts and Runs
- Joe Fabulous
29 Mar 2010 16:29 #357032
by Joe Fabulous
2004 Harley Davidson Softail
1981 Z1000 Chop
1982 KZ1100 A2
XS 650 Plunger Chop (in bits)
Starts and Runs, Won't Start, Starts and Runs was created by Joe Fabulous
Has anybody had this before?
I have a 1979 Z 650, been stood for a long time and then rebuilt. Bike eventually started and runs great, carbs rebuilt, timing spot on, leave it for a day or more and won't start, it just won't suck fuel through even though the carbs are full the plugs stay dry. Put a hand over the back of the carbs it nearly pulls the skin off, sucks through fuel like a porn star and runs great, starts off the button all day, leave it for 24 hours and the same thing again. It does have a nearly almost knackered starter clutch that I'm about to repair so it may be the motor just isn't spinning as much as it should but..........any other ideas?
Bike has a Harris 4/1 pipe and K&N filters, all jetted correctly.
Any ideas most welcome before I kick the living daylights out of it!
1981 Z1000 Chop
1982 KZ1100 A2
- TeK9iNe
- What did you do!?!
- Thank you received: 28
29 Mar 2010 16:32 #357033
by TeK9iNe
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Replied by TeK9iNe on topic Starts and Runs, Won't Start, Starts and Runs
You are using choke to start cold right?
Have you checked to make sure the choke circuit is clean/clear?
Pilots are clean/clear.
Mixture screws are adjusted correctly...
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- Joe Fabulous
29 Mar 2010 17:06 #357040
by Joe Fabulous
1981 Z1000 Chop
1982 KZ1100 A2
Replied by Joe Fabulous on topic Starts and Runs, Won't Start, Starts and Runs
Yep, all done, spotlessly clean, even had a second set of carbs on it and the fault is identical.
1981 Z1000 Chop
1982 KZ1100 A2
- TeK9iNe
29 Mar 2010 18:06 #357060
by TeK9iNe
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Whats the resting voltage of the battery?
You say the plugs stay dry?...
Richen pilot circuit @ the mixture screws slightly and see...
Could be starter clutch too...
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- MFolks
- Thank you received: 540
29 Mar 2010 19:47 #357085
by MFolks
Replied by MFolks on topic Starts and Runs, Won't Start, Starts and Runs
Checked the input voltage to the ignition coils? It should be the same as the battery. If a lot lower, start cleaning the many and various electrical connections.
- gane
- Thank you received: 1
29 Mar 2010 23:15 #357125
by gane
[img][/img] 1977 KZ1000A1
Replied by gane on topic Starts and Runs, Won't Start, Starts and Runs
Silly thought, but if you have a vac. petcock, you might try switching to PRI, for a minute before cranking after extended sets. My thought....everything in the VM carb is related to vacumn/fuel height...Ma kaws' vac petcocks have become "iffy" w/age. & cranking vac could be insufficient to refill 'evaporated/heat related fuel height"in float bowls. useless if manual cock, but a thought. G
- Joe Fabulous
30 Mar 2010 16:13 #357252
by Joe Fabulous
1981 Z1000 Chop
1982 KZ1100 A2
Thanks for all the replies;
Battery fully charged and charging, bike has had a full rewire 2 weeks ago to finish off the rebuild as the original loom was scrap. Voltage at coils etc is fine.
Not going to mess with the jetting as the fault is still there using another set of carbs and I know they are spot on.
Taken the vacuum off the tap for now and only using prime.
We shall see, the starter clutch repair kit arrived today so it should be in next week, i'll let you know. Dave
1981 Z1000 Chop
1982 KZ1100 A2
- JakeB
30 Mar 2010 16:33 #357255
by JakeB
1978 Z1-R
Replied by JakeB on topic Starts and Runs, Won't Start, Starts and Runs
I had an issue similar to this on my last bike. It ended up being the cheap fuel filter I was using. It must have had a small leak that was somehow pressure locking the fuel line as it sat. When this happened, if I pulled the gas cap off and pressurized the tank, the bike would fire right up. I replaced the cheapo filter with a good quality one, and the problem never came back.
You also may want to check that the gas tank vent is clear.
Next time it won't start, try pressurizing the tank for a few seconds and see if it will start then.
Keep us posted.
Keep us posted.
1978 Z1-R
- Joe Fabulous
13 Jul 2010 16:12 #382360
by Joe Fabulous
1981 Z1000 Chop
1982 KZ1100 A2
Well it's been a while since my last post and the result is........starter clutch repair has cured my starting issue in relation to fuel not getting through. It would seem that the engine just wasn't spinning over fast enough to suck the fuel through. Fitted the starter clutch repair kit and engine spins over fine now, loads of fuel getting through even when the bike is left for days at a time it starts straight away. Great result!
1981 Z1000 Chop
1982 KZ1100 A2
- MFolks
13 Jul 2010 17:48 #382390
by MFolks
Nice to hear of a succesfull outcome.
