77 KZ650 Low Oil Pressure?
- paulstanely45
- 1977 KZ650-B
I have a 1977 KZ650B1
Recently I rebuilt my carbs, changed the coils, replaced the regulator rectifier, and converted to electronic ignition. In doing this, I had also replaced the oil filter and done an oil change.
My oil indicator light comes on now indicating that I have low oil pressure. I am using the same type of oil that I used all last year and I had no problems with this last year (I used synthetic 0-40 oil)
Could I have done something wrong putting in the filter or changing the oil? I had done this before with no problem.
I was giving the bike shit today, revving pretty high and it seemed pretty up to the challenge.
Could I have wired something together wrong? Do these sending units every become faulty? What signs should I be looking for to indicate low oil pressure? Would changing the oil filter affect the pickup somehow?
1977 KZ650-B
- Just Yourshadow
- Just taking life as it comes...
1976 KZ900A4
Kerker 4 into 1, Andrews 2X intake Cam, K&N Dropin Filter.
1982 Kz550-H1 GPz
- rstnick
- Thank you received: 377
Make sure the screw is tight and that no part of the Y connector on the end of the wire is touching the engine or the pick up plate.
Sometimes (this has happened to me twice) the blue/red wire will be tight against the pick up plate's edge and the insulation will wear away, grounding the wire and making the light come on.
A bit of electrical tape around the wire, and making sure the wire is not tight up against the plate should help.
Rob
CANADA
1978 KZ650 C2, 130K kms, Delkevic ex, EI, CVK32, PMC easy clutch, ATK fork brace, steering damper, braced swingarm, 18" Z1R front wheel.
2000 ZRX1100
2011 Ninja 250R
2005 z750s
- rstnick
Check the diagram below;
The spring then washer goes below the filter.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R
2005 z750s
- bountyhunter
- Thank you received: 337
Your engine was designed for 10-40 or 20-50.Hey,
- paulstanely45
- 1977 KZ650-B
Would the oil pressure indicator light coming on when the engine is off but the ignition on indicate a ground short?
1977 KZ650-B
- Just Yourshadow
1976 KZ900A4
1982 Kz550-H1 GPz
- rstnick
Once you start the engine, or kick it over a few times, the light will go out once enough pressure is built up.
With the engine running the light should stay off.
While kicking her over, or using the electric starter, the light will go off, but come back on if you don't get her started or if there's an oil issue.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R
2005 z750s
- paulstanely45
- 1977 KZ650-B
I grounded the lead and the light still comes on, so its not the bulb. I suppose Ill remove my points plate and make sure everything is alright.
Ill keep you guys posted.
1977 KZ650-B
- MFolks
- Thank you received: 540
Moisture gets into it and suddenly you have an intermittent connection. Many a person has used this conector on doing trailer hook ups. There's nothing like being under a trailer when it's raining trying to get the stop lights/turn signals to work!
I suggest soldering the connection if possible then cover it with some heatshrink tubing.
- Old Man Rock
- Thank you received: 225
If not, your sensor would be working as designed informing you somethings wrong...
Just a thought....
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- paulstanely45
- 1977 KZ650-B
1977 KZ650-B
