engine poorly
- judgie
27 Mar 2010 07:00 #356511
by judgie
forever tweeking aircooled engines, well it is my job
77 z650c1
engine poorly was created by judgie
well after rebuilding my 650 motor.
glaze busted the bores, proper valve job, mild port work, new coils etc etc
old rings gapped up ok, valve clearance all good i have little or no compresion on all 4 pots.
cam timing seems spot on, only thing i am not 100% sure on is the cam pullys. 95% sure there on the right way and im guessing if they were 180 out i would have valve piston clerance problems.
head is now off the engine and no sign of anything touching.
first thoughts are the rings are to worn and it needs new ones but at £250+ for a set i was thinking of a engine trensplant.
what fits? thinking along the lines of a zephyr 750 motor.
cheers rob
cheers rob
77 z650c1
- Old Man Rock
- Thank you received: 225
27 Mar 2010 07:15 #356512
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Replied by Old Man Rock on topic engine poorly
"have little or no compression on all 4 pots"...
@ 1/4 TDC (ignition timing cover 1/4 on T), cam lobe tips should be facing each other and parallel with the head deck. Is this correct on yours?
On KZ900/1000... Should like as in image on the top right.
Not sure about the KZ650 dimple marks so ignore in this image set for again, this is for a KZ900 but I would think the lobe tips should be the same...
Other KZ650 members should be able to confirm....
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- Motor Head
- Thank you received: 391
27 Mar 2010 07:26 #356517
by Motor Head
Replied by Motor Head on topic engine poorly
Never tried using old rings after honing and would not recommend it! Buy the rings if bore is still at correct size, also make sure off the ring land fit at the piston groove. Sounds like you unbolted the sprockets off of the cam's? The manual will show the proper installment of the sprocket to each cam as well as the proper timing for the cam's to crankshaft. Did the valve clearances get reset after the "proper valve job"?
- Old Man Rock
27 Mar 2010 07:33 #356520
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- judgie
27 Mar 2010 07:42 #356522
by judgie
77 z650c1
Replied by judgie on topic engine poorly
like i said i'm sure the cam sprokets are on correctly, they were removed as i had a pair of big cams when i rebuilt the engine but swapped them back to stock after i couldn't get it to start.
bores were not honed just a light glaze bust.
i have the same pages as posted about cam timing and have tried it at least 4 times by the book and it all comes out right.
checked all the valve clearances and they all came up in spec.
even had a degrea wheel on the crank and the cam timing is is to the book so im pretty sure that is correct
really baffeled by this one and its not as if i dont know engines as i build race engines for a living [aircooled vw motors]
77 z650c1
- Motor Head
27 Mar 2010 08:00 #356523
by Motor Head
Ah another VW man! I spent years on those motors.
So I know its hard to do without having the upper snubbing block in the valve cover holding tension on the chain, but you should have an equal split in valve over lap on TDC 360 crankshaft degrees off of compression stroke. This will tell you if the valve timing is on, look and see if the intake starts to move when turning in 1 direction and the exhaust in the other, equal amounts for the same number of degrees. And the valves should nearly close when on this TDC, all with #1 cylinder. When together you did a compression test, but did you do a leak down test or at least blow air into the cylinders to see where its escaping?
- TeK9iNe
- What did you do!?!
- Thank you received: 28
27 Mar 2010 09:39 - 27 Mar 2010 09:44 #356535
by TeK9iNe
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Replied by TeK9iNe on topic engine poorly
I think OMRs' got this one...
anywho:
judgie wrote:
The same priciples apply here. Compression requires the valves to be seated completely as the piston rises on the compression stroke.
Make sure headgasket is tight.
WOT, all plugs out - Do compression test - list numbers.
Pour 2 teaspoons oil into each cylinder, do another compression test - compare numbers.
Compression rises sharply with oil - bad rings and/or piston combo.
Compression stays nearly the same - Valve seating/cam timing issues.
GL bud!
anywho:
judgie wrote:
So it runs now? That would mean that you have at least 100 pounds compression on 2+ cylinders...swapped them back to stock after i couldn't get it to start.
Glaze bust or not, old bores are old bores... did you spec the pistons to the bores?bores were not honed just a light glaze bust.
OK. If your 100% cam timing etc is perfect...i build race engines for a living [aircooled vw motors]
GL bud!
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Last edit: 27 Mar 2010 09:44 by TeK9iNe.
