- Thank you received: 35
Head gasket question
- moneypit
25 Mar 2010 19:19 - 25 Mar 2010 19:20 #356190
by moneypit
2-76 kz900
St Paul MN
Head gasket question was created by moneypit
Got my valve seat recut so time to put the head back on.
Can or should I reuse the head gasket that has 15 min. idle time back on or use my new Emgo one that came with my gasket kit from z1. I didnt like that ones quality so ordered the oem type also. Which is what i ran.
2-76 kz900
St Paul MN
Last edit: 25 Mar 2010 19:20 by moneypit.
- bountyhunter
- Thank you received: 337
25 Mar 2010 19:54 - 25 Mar 2010 19:59 #356203
by bountyhunter
Replied by bountyhunter on topic Head gasket question
I reused a head gasket only once: it was brand new and installed during the rebuild, and ran maybe five hours. The head and cylinder were super clean and smooth. Then I had to tear the top end off to replace the base gasket that disintegrated (thanks Athena). I used copper spray sealer when I installed the head gasket the second time and it has been perfect for four years. If it is an OEM gasket with 15 minutes on it, I would reuse it but I would use copper sealer.
No guarantees of course. I definitely would retorque it after running it up full hot a couple of times.
Last edit: 25 Mar 2010 19:59 by bountyhunter.
- TeK9iNe
- What did you do!?!
- Thank you received: 28
26 Mar 2010 10:49 #356320
by TeK9iNe
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Replied by TeK9iNe on topic Head gasket question
I would re-use it, with sealer like said.
Re-torque Re-torque Re-torque Re-torque Re-torque Re-torque...
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- moneypit
