My KZ thinks its a Harley, lot of oil out the vent
- 2006hhr
23 Mar 2010 19:01 #355727
by 2006hhr
My KZ thinks its a Harley, lot of oil out the vent was created by 2006hhr
K, my 1979 KZ650 is going through a bout of oil expulsion, if i get on it a bit (and who doesn't) it blows oil out the vent for the crankcase, at a pretty serious amount. Now when i got it, the emission equipment had been modified, the bike had pods and the gulp valve was still attached, with a long hose off it that had a bit of filter element stuffed in it. Not knowing what kind of jury rigged stuff the p.o. had going on, i pitched the gulp valve, ran a piece of hose between the breathers on the valve cover and called it good, now i am wondering if any of this modification is causing my problem, or is the crankcase just overfull and blowing wherever it needs to to relieve itself. I ran out on the freeway today, running with traffic (about 90 or so) and had a nice mist of oil all over the pipe, rear tire and even the seat, not to mention the rear suspension. So am i looking at blowby, or what? Sorry for the long post, just got off a 10 hour shift and running on autopilot. 2006hhr
- Thank you received: 2829
23 Mar 2010 19:53 - 23 Mar 2010 19:54 #355735
by 650ed
Replied by 650ed on topic My KZ thinks its a Harley, lot of oil out the vent
Are you filling the oil up to a point between the 2 lines on the oil window with the bike on its centerstand? Ed
Last edit: 23 Mar 2010 19:54 by 650ed.
- PLUMMEN
- Thank you received: 104
23 Mar 2010 19:53 #355736
by PLUMMEN
Replied by PLUMMEN on topic My KZ thinks its a Harley, lot of oil out the vent
have you checked the oil?
- 2006hhr
23 Mar 2010 20:33 #355746
by 2006hhr
Replied by 2006hhr on topic My KZ thinks its a Harley, lot of oil out the vent
K had some dinner and got a chance to unwind. It is overfilled, so going to change oil and filter this weekend anyway. Just surprised me with the Exxon Valdez imitation. Most days i am riding in town so not much high end antics. On a good note, the mystery pipe (see
kzrider.com/index.php?option=com_kunena&...ew&catid=2&id=351674
looks, sounds and performs very well.
- Old Man Rock
- Thank you received: 225
24 Mar 2010 05:09 - 24 Mar 2010 05:34 #355767
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Replied by Old Man Rock on topic My KZ thinks its a Harley, lot of oil out the vent
While you're at it, after changing the oil & oil filter.... check the oil pressure as well....
Have you confirmed oil is getting up top?
OMR
Just in case.... KZ900/1000
Your KZ650- should be something similar I would think....
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Last edit: 24 Mar 2010 05:34 by Old Man Rock.
- timebomb33
24 Mar 2010 10:02 #355825
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic My KZ thinks its a Harley, lot of oil out the vent
if it's overfilled it may be due to bad needles and seats in your carbs give the oil the smell test see if there is gas in it oil can't multiply by it self so unless your adding too much oil my guess would be its filling up with gas,
