Gear shift oil seal
- morhaven
22 Mar 2010 18:25 #355502
by morhaven
Gear shift oil seal was created by morhaven
- morhaven
22 Mar 2010 19:01 #355512
by morhaven
Replied by morhaven on topic Gear shift oil seal
Also what is this oil sealed called.. for me to go order one ?
- MFolks
- Thank you received: 540
22 Mar 2010 19:22 #355518
by MFolks
Replied by MFolks on topic Gear shift oil seal
Remove the engine sprocket cover to see what's leaking. I suspect what you're seeing may be chain lube.The clutch adjustment panel may have to opened to re-adjust the clutch cable after you have installed the sprocket cover.
On some Kawasaki's the foot peg assembly will have to be removed along with the starter motor cover.
I think if you had a leak, it would be noticed on the chain and directly below the engine as a spot or two.
- morhaven
23 Mar 2010 03:57 #355551
by morhaven
The bike is a Shaft Drive, see picture attached of the
I see its leaking at the oil seal where the gear shifter is.
How do I replace the oil seal?
can I still buy these?
- morhaven
23 Mar 2010 09:59 #355625
by morhaven
Would I need a special tool to remove this Seal?
- Skyman
- 1978 KZ1000-B2 LTD 1982 KZ1000-M2 CSR
- Thank you received: 3
23 Mar 2010 10:29 - 23 Mar 2010 10:32 #355629
by Skyman
West Linn, OR
Replied by Skyman on topic Gear shift oil seal
I "think" I may have replaced this seal on one of my bikes before. If I did, I did not have to open up the case, or anything major like that (I definitely would have remembered THAT ).
I think I was just able to pry it out with a hook pick, and pop the new one back in.
The seal should still be available. Are you in N. America? If so, call Z1 Enterprises, and if it is available, they can get it for you (even if you don't find it on their website).
I think the part number you need is 92049-004.
West Linn, OR
Last edit: 23 Mar 2010 10:32 by Skyman.
