cam chain noise
- nikkaw88
- pburnhamb
- Thank you received: 2
1978 kz650b (810, 750 head)
1976 kz900
1977 xs650
- nikkaw88
- shizzomynizzo
I was thinking it was just how they sounded at higher revs, but now you got me thinking.
the sound is not like my honda cam chain sounds when it need adjusting.
i have an 81 550
24 hours in a day...24 beers in a case
1981 KZ550 ***SOLD***
1982 KZ1100 A2
- pburnhamb
-patrick-
1976 kz900
1977 xs650
- shizzomynizzo
My honda has a nut that you loosen when the engine is at 15 degrees past tdc.
1982 KZ1100 A2
- gottmoore
This subject is fully covered, and will help
- st4lifesd
- TeK9iNe
- What did you do!?!
- Thank you received: 28
I also have a 81 KZ550 standard and i have noticed much noise coming from the top of the cylinder heads. My bike makes most of these noises while idling. It runs fine in lower RPMs but will usually max out in any gear around 5-6k rpms. That cant be normal, can it?
No, that is not normal.
Check all your cam to shim clearances and the cam chain tentioner first.
Have you messed with the main jets/jetting at all?
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- st4lifesd
