- Thank you received: 1
Cam cap bolt stripped!
- polkat
21 Mar 2010 17:11 #355270
by polkat
Cam cap bolt stripped! was created by polkat
Putting the cams back in my 750-4 and one of the cap bolts wouldn't tighten (didn't go beyond torque spec). Needles to say, it came back out of the head with aluminum stuck in it's threads.
Can I heli coil this? And what size would I be looking for? Thanks!
- timebomb33
- Thank you received: 10
21 Mar 2010 17:17 #355275
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic Cam cap bolt stripped!
yes you can heli coil it 6x 1mm is the one your looking for not a big deal happens all the time i just stripped 2 today my self. and it took me less then 10 mins to fix including finding my dam helicoils in the first place alot of people on here prefer timeserts but unless you have a kit already they are expensive. helicoils if done properly will have no problem living as long as the bike they are being installed into.
- timebomb33
21 Mar 2010 17:24 #355283
by timebomb33
your not having much luck are you.
- KZ1100 Bully
21 Mar 2010 18:03 - 21 Mar 2010 18:04 #355304
by KZ1100 Bully
1983 Kawasaki KZ1100 Spectre D2
Replied by KZ1100 Bully on topic Cam cap bolt stripped!
I just did one of mine last week, worked really well.
Here is what I used, same day shipping:
cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=290335959914
Last edit: 21 Mar 2010 18:04 by KZ1100 Bully.
- Motor Head
- Thank you received: 391
23 Mar 2010 17:57 #355704
by Motor Head
Replied by Motor Head on topic Cam cap bolt stripped!
You can also buy a stepped stud, it will be 6X1.0mm at the 1 end and probably 8X1.25mm at the other. Then a drill bit and tap, might be cheaper than a heli-coil set.
