Leaky crank seal
- Macf85
21 Mar 2010 08:15 #355140
by Macf85
Leaky crank seal was created by Macf85
I'm new to the forum. I have an '81 KZ550 with a right side crank seal that has a mild leak. Does anybody know if the seal can be replaced without splitting the engine case? The factory service manual doesn't specifically show the replacement procedure for the seal. I already ordered the seal but if the case has to be split I'll probably just leave the old one in until it gets too bad to ignore.
Thanks for any help I can get.
- Old Man Rock
- Thank you received: 225
21 Mar 2010 08:32 #355143
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Replied by Old Man Rock on topic Leaky crank seal
PM LoudVHX for he's extremely well knowledge on these KZ550;) ....
Ok, electrical as well no doubt... :laugh:
OMR
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- Macf85
21 Mar 2010 08:37 #355146
by Macf85
Replied by Macf85 on topic Leaky crank seal
Thanks. I tried to search the forum but didn't find anything specifically for the 550 crank seal. I'll try to PM LoudVHX.
- otakar
21 Mar 2010 08:43 #355148
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
Replied by otakar on topic Leaky crank seal
It is not going to be as simple as it is on the KZ900/1000/1100 that has the separate ignition housing that can be removed and the seal can be knocked out from the inside once this housing is removed. But I believe once you remove your timing advancer, you should be able to peal out the seal. It will take more work but should be doable. But LoudVHX should have your answer for sure. He is the 550 Guru, Zen-Master.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- Macf85
21 Mar 2010 08:56 #355150
by Macf85
Thanks. I sent him a PM. If the case does have to be split I'm gonna live with a little oil on my boot. It only drips out the ignition cover when you're really heavy with the throttle hand. I hope the seal can be pried out without getting some expensive tool or the risk damaging anything else.
- otakar
21 Mar 2010 09:02 - 21 Mar 2010 09:09 #355152
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
There are "HOOK stile seal tools" available for this kind of seal removal. The one I am thinking of looks like a small dent puller with a small but wide hook at the end.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 21 Mar 2010 09:09 by otakar.
- Macf85
21 Mar 2010 09:15 #355158
by Macf85
I've seen those too. A slide hammer with a hook on one end. If I use something like that I want to make sure I'm able to successfully get it out without making the situation worse.
- TeK9iNe
- What did you do!?!
- Thank you received: 28
21 Mar 2010 09:23 #355163
by TeK9iNe
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Replied by TeK9iNe on topic Leaky crank seal
I pull 2-stroke dirtbike crank seals all the time.
Just get 2 tiny self tapping sharp screws and screw them into the seal on either side, just about 4 threads, then pull the seal right out by them.
Installation is equally easy. Just use a socket matching the seal size and a small block of wood as a drift.
Use a rubber mallet to smack the drift and make sure to grease everything liberally first.
GL
GL
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
