- Thank you received: 1
Wooden piston stops?
- polkat
Recently I read a post on some forum where the guy made some wooden stops to go under the pistons to hold them steady. He made his 1/2" thick. I tried this and the wood just flops around under the piston. But I like the idea. What did I do wrong? Seems they should be thicker.
- timebomb33
- Thank you received: 10
I THINK MY POWERBAND BROKE
- polkat
- TeK9iNe
- What did you do!?!
- Thank you received: 28
Theyre really thin and easy to use, and cheap.
..and thier pro!
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- bountyhunter
- Thank you received: 337
I got some little paint stir sticks from Home Depot and cut them and stacked them to make the piston rests (duct taped them together). Worked really well.Recently I read a post on some forum where the guy made some wooden stops to go under the pistons to hold them steady. He made his 1/2" thick. I tried this and the wood just flops around under the piston. But I like the idea. What did I do wrong? Seems they should be thicker.
- KZ1100 Bully
I understand how to do it (but thanks). I just am not sure what deminsions the wood should be (how thich from top to bottom)? My manual (the kawasaki one) doesn't mention anything but the factory tool.
These are the ones I made. I placed them under the two center pistons and I did not have to turn crack to get the outside pistons. They made the job so very easy. Just take your time and do one ring at a time, cylinder weight did all the work.
So I used 3/4 in thick ply wood 2" inch wide and 5" inches long, cut the same 1/2 grove down the middle
1983 Kawasaki KZ1100 Spectre D2
- fordtruck
- Thank you received: 6
Here's what they look like:
'77 KZ1000-MTC 1075 kit. Stage 1 port
- polkat
Thanks everyone!
