- Thank you received: 1
Help me do this right this time!
- polkat
19 Mar 2010 19:24 - 19 Mar 2010 19:26 #354681
by polkat
Help me do this right this time! was created by polkat
1982 KZ750H3. Finally got my pistons/rings sorted out and will slip the block down on them tomorrow. The rear cam chain tensioner goes into crankcase first with the little black plastic cushions up, and the block slips over that and the pistons. Then the front cam chain tensioner can be fitted into the block from above once the block is down.....right?
Last edit: 19 Mar 2010 19:26 by polkat.
- TeK9iNe
- What did you do!?!
- Thank you received: 28
21 Mar 2010 10:03 #355172
by TeK9iNe
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Replied by TeK9iNe on topic Help me do this right this time!
Yes, I believe that is correct.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
