Manual Cam Chain Tensioner Adjustment
- po boy
19 Mar 2010 08:21
What's the correct way to adjust the manual cam chain tensioner. My KZ had one when I got it. I just adjusted the valve clearance and want to make sure it's not too tight or loose.
1980 KZ750E1
2002 Hayabusa
2002 Hayabusa
- otakar
Re: Manual Cam Chain Tensioner Adjustment
19 Mar 2010 08:25
This was covered in quite some length about two weeks ago. Just go back some posts or "Key word" it. and you will find the entire procedure.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- RonKZ650
19 Mar 2010 10:05
Do you mean the Kawasaki manual tensioner? or the APE aftermarket one? Couple weeks ago was discussion on the APE, but I would assume you have the older factory Kawasaki tensioner. If so:
Take off your right side engine ignition cover, turn the engine over slowly clockwise with a 17mm wrench or socket while looking at the timing plate, after the 2-3 timing marks pass you'll see the plate has a corner where it turns from rounded to flat, right at this point stop turning with this corner at the timing pointer, use a 10mm wrench to loosen the jamnut on the tensioner adjust bolt, loosen the bolt a turn, then tighten the bolt, tighten the jamnut, reinstall your cover and the job is done.
- po boy
19 Mar 2010 12:34
No, mines an APE.
I did a search on the forum before I ever posted this topic but didn't find anything that matched.
I'll try again.
I'll try again.
1980 KZ750E1
2002 Hayabusa
2002 Hayabusa
- otakar
19 Mar 2010 12:51
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
