- Thank you received: 82
Four engine questions '78 1000 A2
- testarossa
1) Should I worry about getting into my oil pump to check the clearances inside? Doesn't look like that gasket is in a rebuild set. Do the pumps ever give trouble?
2) My Clymer manual says that 20 links of the cam chain should measure less than 6.21" However there is no drawing to show you where to measure. What I mean to say is do they want you to measure from the far end of link #1 to the opposite end of link #20 or do you measure from the the front pin on #1 to the same side of the same pin on #20? Hope that makes sense. The chain looks new, and I can't detect any slop. It's measures longer than 6.21" if you use the first method that I described. Or do I just replace it? $40, cheap insurance.
3) My manual states that the carbon ridge at the top of the cylinder should not be removed if the original pistons and rings are being reused. Does this mean that I shouldn't hone the cylinders before I re-assemble? I would normally hone the cylinders on any other engine to break the glaze.
4) As I stated before, my clutch friction discs will need replacement, but I discovered extra plates in my clutch. Z-1e's website says 8 fiber discs and 7 steels for this bike. I have 10 fibers and 9 steels. Two of the steels are noticably different than the other 7, but all of the fibers look the same. So is it 8 or 10? I never got to ride the bike, but the clutch actuation was quite stiff. could this be due to the four extra discs putting more preload on the springs?
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
- timebomb33
- Thank you received: 10
I THINK MY POWERBAND BROKE
- PLUMMEN
- Thank you received: 104
2.are you splitting the cases?if you are definately throw a new chain in there.dont forget the guides and rolers
3.is there a ridge on top of your cylinder?that suggests excessive wear to me anyway.measure pistons and bores
- testarossa
2004 ZX-10R
Angola, IN
- testarossa
1.check the pump for slop or grooves in gears or pump body
Thanks Plummen. Boy did I ever split the cases. The ridge, if you can call it that that does exhist is just carbon buildup. I carefully measured my bores and pistons. The results are in my build thread on page 9 IIRC. I'm thinking of doing the cam chian even if it is good. this would allow me to put the 1075 kit in later without splitting.
2004 ZX-10R
Angola, IN
- timebomb33
- larrycavan
- Visitor
Work Smart - Not Hard
1- Leak test it
2- Manually turn the motor over with the valve cover removed to inspect cam chain for stretched spots.
3 - If it's got the extra plate clutch kit in it, the damage may have already been done to the basket. Inspect the fingers for grooves / ridges. Those clutches are no good on street bikes, especialy a stock motor. The stock clutchs is the best clutch you're ever going to find for a street ride.
- timebomb33
- testarossa
Why take it apart with the intention of putting it back together with the same used parts...if possible?
1- Leak test it
I took it apart for two reasons.
1) I needed to replace the crankshaft. The alternator rotor had spun, and I was advised by other members that the only permanent solution was to replace the crank and rotor.
2) I wanted to. I like to tinker, its a hobby. I wanted to make sure that there were no foreign bodies in the crankcase or combustion chambers. The bike had been sitting outside for 15 years. I'm also prepping for a later 1075cc kit with mild cams and port work. Wanted to make sure that the lower end was all good, so that I can simply pop off the head and jugs without getting any further into the motor at that time.
I'm sure you'll want know, why not do the 1075cc now? Well I never got to ride the bike stock, and would like to know how much improvement I get. I'm also spending considerable time and effort and about all my money to build and paint the bike.
2004 ZX-10R
Angola, IN
- larrycavan
- Visitor
- nads.com
- Thank you received: 20
So what keeps the new chain from strectching as well? I think mine is stretchedddd, and so is the drive chain. ??????? Do I just keep tensioning the new one until it stops stretching? And then what do I got? A need for yet another chain? ?? Do they just keep stretching then finally break or what?Why take it apart with the intention of putting it back together with the same used parts...if possible?
1- Leak test it
- testarossa
2004 ZX-10R
Angola, IN
