- Thank you received: 1
Minimum ring gap?
- polkat
18 Mar 2010 20:34 #354436
by polkat
Minimum ring gap? was created by polkat
'82 KZ750 four. The book says that the maximum piston ring gap is .7mm but gives no measurement for the minimum gap. I know that if the gap is too small, the rings can lock to the bores when they heat up. Mine range from .53mm to .58mm. Am I okay?
- bountyhunter
- Thank you received: 337
18 Mar 2010 21:54 #354452
by bountyhunter
Replied by bountyhunter on topic Minimum ring gap?
The rule I read when I researched this is you need at least .003" - .004" for each inch of bore diameter. In other words, if the piston is 3" diameter, the minimum ring end gap would be .009" - .012".
"Mine range from .53mm to .58mm. Am I okay? "
If my math is right that's about .021" - .023" which should be more than enough.
- timebomb33
- Thank you received: 10
19 Mar 2010 18:12 #354651
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic Minimum ring gap?
polkat as bountyhunter has said they look like they would be still decent to reuse right in the middle of the spec. and i use the .003-.004" per inch of bore rule myself.
- polkat
19 Mar 2010 19:46 #354695
by polkat
Replied by polkat on topic Minimum ring gap?
Got it. Thanks guys!
