- Thank you received: 225
What oil should I run?
- Old Man Rock
19 Mar 2010 18:06 #354647
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Replied by Old Man Rock on topic What oil should I run?
Designed for wet clutch engines...
Expensive @ ~ $9 a quart, sure but so was my KZ build so why use anything less is the way I look at it... Runs smoother, cooler and better lubrication and yes you can actually hear the difference in the LISKA idler gear so why not pay the xtra little cost...
Same time, regular oil and filter changes using Dyno oil, not a problem for this is all they had back in the 70's...
OMR
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- PLUMMEN
- Thank you received: 104
19 Mar 2010 18:46 #354666
by PLUMMEN
Replied by PLUMMEN on topic What oil should I run?
id say buy the best cheap oil you can get easily,that oughta narrow the field! :laugh: ifthe motor has 30,000 unknown miles already i wouldnt get too fancy
- Old Man Rock
19 Mar 2010 20:52 #354726
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
"id say buy the best cheap oil you can get easily,that oughta narrow the field! "...
Yeah, look at plummens avatar... Cheap doctor in Nebraska did wonders for him...:blink: :huh: :dry: :laugh:
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- Thank you received: 2098
20 Mar 2010 03:16 - 20 Mar 2010 03:56 #354791
by Patton
Replied by Patton on topic What oil should I run?
Remembering back when the old filling stations had a rack to drain and collect the last few drops from oil cans that had just been emptied into a crankcase.
The freshly emptied oil can was placed upside down on the rack to drip drip drip.
Now that must have resulted in some truly unique blends. :laugh:
But it was indeed new oil. And sold at a discount.
Last edit: 20 Mar 2010 03:56 by Patton.
- Old Man Rock
20 Mar 2010 07:26 #354827
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
And we wonder why some of these old cars no longer run past 70K miles or so.... :huh: :dry: :laugh:
Another thing I forgot to mention, AZ heat index... 115*F :ohmy: :blink: in the summer, oh yeah, synthetic makes a difference...
OMR
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- otakar
20 Mar 2010 08:54 - 20 Mar 2010 09:00 #354841
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
Replied by otakar on topic What oil should I run?
You wont go wrong with Shell Rotella-T Mineral or synthetic on a stock bike. Has everything the bike requires. Wall-Mart between $13-$18 /Gallon jug, depending on which flavor you want M or S. The high performance antique car guys swear by it, and so do many if not most of us. I called Shell and YES it still has more than enough ZDDP.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 20 Mar 2010 09:00 by otakar.
