Is it real,or is it memorex
- Iron Duke
- what are you rebelling against?
1982 KZ550 LTD C-3
1979 XS1100 F Yamaha
- N0NB
- Blue handles better
Nate
1979 KZ650 (Complete!)
1979 KZ650 SR (Sold!)
1979 KL250 (For sale)
1994 Bayou 400 (four wheel peel )
- testarossa
- Thank you received: 82
There is soo much info in there about oil that your head will spin. Plenty of MC specific stuff too. The long and the short of it is that the synth isn't really any better in most cases. You don't have any warrantee concerns, so save yourself some money.
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
- bountyhunter
- Thank you received: 337
To continue use dino, or change to synthetic. My ride has right at 30K showing on speedo, doe's not smoke,has very good compression,but po might have done a rebuild I don't know. Right now I;m using dino oil from Yamaha, and would like to know if an MC with that many miles can be changed over to synthetic without any negatives,what would be the pros and cons of a change over? thanks Duke
You can change directly to syn without flushing no worries. Main advantages of syns are that they have inherently more stable viscosity and hold up better under temp stress.
- z650c3
Cheers
C3
1979 z650 c3 first registered in 1981
2006 Harley Davidson VRSCR
Northern Ireland
- Thank you received: 2829
Oil Description
- gottmoore
Another friend on a Vulcan told me the same thing, except he said to use a specific MC oil as car oil isn't detergent enough and will gunk things up eventually.
Im stickin w/ dino.
- Iron Duke
1982 KZ550 LTD C-3
- will61310
- Thank you received: 6
...1980 LTD 1000...
the guy I bought mine from told me not to use synthetic. He told me it made the bike leak at all gaskets and trashed the clutch. When I got it, he had just redone the clutch and all seals.
Im stickin w/ dino.
Your friend was wrong about synthetic MOTORCYCLE oils. However, synthetic CAR oil has friction modifiers that probably would cause clutch issues. I suggest you go to the Mobil1 link I provided above and read the description. It discusses clutch. If your bike leaks oil it will still leak oil. If it doesn't leak it won't leak. Ed
- Iron Duke
1982 KZ550 LTD C-3
- Iron Duke
1982 KZ550 LTD C-3
