Since I am a newbie got a stupid question
- bigD82kzltd
David
1982 kz1000 ltd 4 into 1 vance and hines with baffle and pod filters. stock engine that was rebuilt but don't know at how many miles
- Bad Dad
76 KZ900LTD
82 GPz750R1
01 VULCAN 800A-CHOPPED
76 IRONHEAD-CHOPPED
77 RD 400 Cafe
- BSKZ650
- Thank you received: 14
77 ltd1000, current rider
76 kz900, just waiting
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
- gkz1000st
1979 kz1000st dyna s, wiseco 1075, accel coils, k&n filters,4 into 1 header ,shoei fm5 fairing. Mt.pearl Newfoundland
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- Kawickrice
- Thank you received: 18
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- jayw704
1978 KZ1000
Go Loud and go fast or dont go at all!!!
- Thank you received: 2098
...need to rebuild the petcock...runs fine on reserve...just had the tank repainted and I think that the diaphragm might have got some crap in it at that time....
Oem Vacuum petcock on 1982 KZ1000LTD (see image below)---
Would remove petcock from the fuel tank, then disassemble, inspect, and carefully clean petcock pick-up tube screen and petcock internal parts.
Likely find grit or crud on the screen or inside the petcock impairing the diaphragm action, 0-ring, spring, or position gasket.
But the diaphragm or 0-ring or gasket may be damaged beyond further service, thereby requiring rebuild kit.
If parts look okay, reassemble and see what happens.
In any event, before reinstalling petcock, would remove fuel tank and flush it by fast dumping all existing fuel through filler hole, put in a little fresh fuel, slosh it around, and again fast dump. Idea being to flush loose crud and grit from inside the tank. If desired, may use common household rubbing alcohol for the flushing operation.
Would also check and assure integrity of vacuum hose and connections from carb to petcock.
For reference, here's the diagram from kawasaki.com.
[Click on image to enhance view.]
Likely get better advice if show bike info in signature, and the next few posts show an easy way to do it.
Thereafter, at the end of all your posts, past, present, and future, the same signature information will appear.
And such information may be changed whenever desired.
