Since I am a newbie got a stupid question
16 Mar 2010 01:31 #353775 by bigD82kzltd
Since I am a newbie got a stupid question was created by bigD82kzltd
I know that I need to rebuild the petcock on my bike. It runs fine on reserve. Is there any downfalls to running the bike on reserve compared to the on position? In the on position whenever I rev the engine up past three thousand RPM's it will just cut out and not start kicking again til it comes back down to idle. But in the reserve position it runs great. I just had the tank repainted and I think that the diaphram might have got some crap in it at that time. just wanted to make sre there will be no adverse effects on anything for the time being.
David
1982 kz1000 ltd 4 into 1 vance and hines with baffle and pod filters. stock engine that was rebuilt but don't know at how many miles
16 Mar 2010 01:50 #353776 by Bad Dad
Replied by Bad Dad on topic Since I am a newbie got a stupid question
I don't see any problems running on reserve... cept that you may forget to fill up, and run out! :) The carbs don't know the difference...
76 KZ900LTD
82 GPz750R1
01 VULCAN 800A-CHOPPED
76 IRONHEAD-CHOPPED
77 RD 400 Cafe
16 Mar 2010 05:09 #353790 by BSKZ650
Replied by BSKZ650 on topic Since I am a newbie got a stupid question
sounds like some trash on the screen inside the tank, since you just got it painted, maybe the dust from sanding is still inside the tank, and has plugged up the screen
77 ltd1000, current rider
76 kz900, just waiting
16 Mar 2010 06:17 #353796 by otakar
Replied by otakar on topic Since I am a newbie got a stupid question
Unless the reserve spout is missing the screen and you are siphoning garbage into your carburetors. Do you have a inline fuel filter on the feed line? If not than I would strongly recommend that you put one on. At that point it makes no difference weather you are on main or reserve. Unless you have a vacuum petcock in which case it is a totally different story.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
16 Mar 2010 06:53 #353800 by gkz1000st
Replied by gkz1000st on topic Since I am a newbie got a stupid question
Otakar ,Just wondering what difference it would make if it was a vacuum petcock.I just finished my rebuild and have been using reserve (79 kz1000st)and got a hesitation after idle and was thinking it was my carbs.
1979 kz1000st dyna s, wiseco 1075, accel coils, k&n filters,4 into 1 header ,shoei fm5 fairing. Mt.pearl Newfoundland
16 Mar 2010 07:00 #353802 by otakar
A vacuum petcock is actually a vacuum solenoid. I it is not operating properly it may not be opening and not sullying fuel. The reserve is usually a bypass for that system.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • Kawickrice
16 Mar 2010 07:27 #353806 by Kawickrice
Replied by Kawickrice on topic Since I am a newbie got a stupid question
With the old bikes running on reserve it "WILL" suck up any trash in the tank, then it will get into the carbs and run like crap. If you like pulling the carbs running on reserve is fine. You can get a petcock at Z1E for under 20 bucks.
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
16 Mar 2010 07:31 #353808 by otakar
As I mentioned before, an inline fuel filter will do wonders also $2.50
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
16 Mar 2010 07:57 #353820 by jayw704
Replied by jayw704 on topic Since I am a newbie got a stupid question
I agree running in reserve is ok except for the fact that all the garbage at the bottom of the tank will go right to the carbs. A in line fuel filter will solve that problem for a couple of bucks but remember to change the filter when you do an oil change to keep fuel flow good!
1978 KZ1000
Go Loud and go fast or dont go at all!!!
16 Mar 2010 09:17 - 16 Mar 2010 09:27 #353831 by Patton
Replied by Patton on topic Since I am a newbie got a stupid question
bigD82kzltd wrote:
...need to rebuild the petcock...runs fine on reserve...just had the tank repainted and I think that the diaphragm might have got some crap in it at that time....
Oem Vacuum petcock on 1982 KZ1000LTD (see image below)---
Would remove petcock from the fuel tank, then disassemble, inspect, and carefully clean petcock pick-up tube screen and petcock internal parts.
Likely find grit or crud on the screen or inside the petcock impairing the diaphragm action, 0-ring, spring, or position gasket.
But the diaphragm or 0-ring or gasket may be damaged beyond further service, thereby requiring rebuild kit.
If parts look okay, reassemble and see what happens.
In any event, before reinstalling petcock, would remove fuel tank and flush it by fast dumping all existing fuel through filler hole, put in a little fresh fuel, slosh it around, and again fast dump. Idea being to flush loose crud and grit from inside the tank. If desired, may use common household rubbing alcohol for the flushing operation.
Would also check and assure integrity of vacuum hose and connections from carb to petcock.
Good Fortune! :)
For reference, here's the diagram from kawasaki.com.
[Click on image to enhance view.]
Last edit: 16 Mar 2010 09:27 by Patton.
16 Mar 2010 09:57 #353835 by Patton
1982 KZ LTD could be 440, 550, 750, or 1000.
Likely get better advice if show bike info in signature, and the next few posts show an easy way to do it. :cheer:
Thereafter, at the end of all your posts, past, present, and future, the same signature information will appear.
And such information may be changed whenever desired.
16 Mar 2010 09:58 #353836 by Patton
