Clutch Replacement.
- BIGD
Clutch Replacement.
15 Mar 2010 05:40
With the help of this site, it has been determined my clutch needs replacing. It is probably original. What parts in the clutch need replacing, or do I need to take it apart first. I would like the job to be done right. When I need to order parts would Z1 Enterprises be one of the choices, or would OEM parts be the best for this job. Thanks in advance. Info on this site has been extremely helpful.
Had 1981 KZ1000 M1 From 1981-1995 Canadian Model
Have 1981 KZ1000 M1 US Model
- otakar
Re: Clutch Replacement.
15 Mar 2010 06:29 - 15 Mar 2010 06:35
It is very simple to find out what you require. I thought I needed a clutch also, but it only wound up requiring clutch springs. Those are MUCH cheaper than a clutch. First of all Z1E can get you what ever you require. If your springs are more than 10 years old, than it is almost for sure that they will be. Mine wee so bad that when I shifted into second and third and punched it, the engine revved to about 10K until it heated up enough to displace the oil and catch. The springs are only about $15-$20 for the set, and are very simple to change. The clutch pack is on the other hand more costly. First of all you will require a clutch cover gasket. That you know that you will require for sure. If you have Phillips head screws on the clutch cover, you should also replace those also with Allan head bolts because you are guaranteed to bugger up some of the Phillips heads. If you have Allans already you are set.
1) Remove clutch cover.
2) Remove 5 bolts holding clutch springs.
3) slide out friction plates and steel plates.
4) Wipe off friction plates and measure each one in a couple of spots to see if they are in spec. Most likely you will find out that they are well in spec and they will just require de-glazing.
5) If plates are under spec than just order the entire APE kit with plates and springs from Z1E for about $100.
6) if plates are in spec than just order the springs.
7) very carefully remove old gasket from both surfaces using a either a gasket scraper or a single edge razor blade.
if old clutch is GOOD than de-glaze with a plastic scrubbing pad (Scotchbrite pad)Do this in a soapy water solution using a strong dish washing soap solution. Make sure that you de-glaze both the friction plates and steel plates.
9) allow to dry
10) reassemble everything, make sure you leave gasket dry.
If you require the clutch than this is what you will require.
www.z1enterprises.com/detail.aspx?ID=1490
If your plats are good than you will require this.
www.z1enterprises.com/detail.aspx?ID=319
But fore sure you will require this.
www.z1enterprises.com/detail.aspx?ID=2685 .
I am running a lot of horse power on my bike and I have not warn out the stock clutch.
9) allow to dry
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 15 Mar 2010 06:35 by otakar.
- timebomb33
15 Mar 2010 08:23
ditto to not wearing out the stock clutch with a lot of power never really hurt one yet.
I THINK MY POWERBAND BROKE
- TeK9iNe
- What did you do!?!
15 Mar 2010 08:27
That will simply not do Otto. :woohoo: :laugh: :laugh:
Super easy!
GL!
Super easy!
GL!
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- BIGD
15 Mar 2010 13:08
Thank You!
- bountyhunter
15 Mar 2010 13:38
The rings were installed by somebody with OCD like that Monk detective who can't stand it if things are not properly lined up....:laugh:
- otakar
15 Mar 2010 14:52
Just to update my notes. I just realized that you have an 81 1000M1 this means that you have Alan bolts already installed. This will make the job a bit quicker. Also make sure ABSOLUTELY SURE that you never use oil with EITHER OR PTFE or MOLLY these substances will load up a clutch in a jiffy and it will slip like crazy. If you think that you may have already used these substances than soak the plates in a water based solvent (strong degreaser) like ZEP Citrus Cleaner. This can be bought at Home Depot. Use the "scotch brite" pad to scrub the friction pads to remove any and all of these substances. This can also be used to clean a greasy engine or rear wheel loaded with chain lube. If you use it on the tire (which is fine) make sure that you use some lemon oil or other furniture oil on the tire so it will not dry out on you prematurely. For more info on the proper oil to use in your bike go to this link.
kzrider.com/index.php?option=com_kunena&...ew&catid=2&id=352062
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- MFolks
15 Mar 2010 15:07
Your steel plates can be roughed up using a dual action sander with some 120 grit sandpaper.Wash off the plates afterwards to remove any grit/metal particles.
- otakar
15 Mar 2010 15:18 - 15 Mar 2010 15:21
I found the Scotch Brite pad more than adequate for the steel plates also. They do not have to be that rough. If you make them too rough they will eat up the clutch plates. You really just want to deglaze them. Once I replaced the springs and washed my clutch the thing grabs instantly when released.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 15 Mar 2010 15:21 by otakar.
