- Thank you received: 80
Thank You APE ! ! !
- CoreyClough
- GPz550 Addiction
14 Mar 2010 10:06 #353296
by CoreyClough
'85 GPz550(ZX550-A2)
Thank You APE ! ! ! was created by CoreyClough
Just want to thank APE for doing an excellent job with my ported head I sent them to have rebuilt. It came on a GPz550 with a 615 kit, and Megacycle Cams I bought for $260.00 back in 2006.
THEN:
NOW:
Yea, I know, it was a great score!!!!
Anyhow, I sent it in to them to have rebuilt, and install a new set of RD Springs (stiffer for higher reving), and a set of Viton Valve Seals, along with a set of new Kawasaki Seals, and additional keepers. The Viton Valve Seals wouldn't work, so they used the other ones. APE knows I'm using this head for racing in AFM this year, so they sped up the rebuild process for me. They found out the valves in there were mushroomed, so I sent them another used set. They made a set of bronze valve guides to replace what was in there. Noticing the pitting on the head surface, they recommended surfacing the head till the marks were removed, and only removed what was necessary. I have about .006" remaining on the step, raising the compression about 1/4 percent Jay estimates. Bottom line, cleaned up, and not knowing the history of this head, and who did the work, I'm excited to get this engine together with the 615 kit and cylinders I had APE machine for me a few years ago.
Thinking of sending them a crank flywheel, and rods to lighten and balance, before I install all of this, doing it ones and doing it right, but it might go over my budget I thought I had when I started. I'll e-mail APE Monday.
I do not work for APE, and this is not a paid advertisement, but having sent them work in the past, and receiving great customer service then, I'll be continuing to send them work in the future. Having more than enough parts to build 6 GPz550s, and 7 GPz550 Engines, I'll have spares for a long time.
Thanks Jay, Jeff, and the whole APE Crew! You all know your stuff.
THEN:
NOW:
- larrycavan
- Visitor
14 Mar 2010 10:18 #353299
by larrycavan
Replied by larrycavan on topic Thank You APE ! ! !
Corey,
The bike looks awesome!
Good luck with the racing. Nice to see those old 550's still out there.
Larry C
Larry C
- CoreyClough
- GPz550 Addiction
14 Mar 2010 12:33 - 14 Mar 2010 12:41 #353356
by CoreyClough
Replied by CoreyClough on topic Thank You APE ! ! !
Thanks Larry. If I had a GPz750 turbo, I'd venture into the same performance upgrades you have.
Intake Port
Exhaust Port
Combustion Chamber
Head Surface Step
Intake Port
Exhaust Port
Combustion Chamber
Head Surface Step
Last edit: 14 Mar 2010 12:41 by CoreyClough.
- mark1122
- Keep twisting it
- Thank you received: 109
16 Mar 2010 10:46 #353850
by mark1122
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Replied by mark1122 on topic Thank You APE ! ! !
Your bike looks great Corey.
if u take a drumel to the air pasages around the ports and fins,to remove the factory slag, it will help to cool it better. It was also popular for the racers to drill 3/8" holes through the cooling fins.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- N0NB
- Blue handles better
16 Mar 2010 16:11 #353901
by N0NB
Nate
1979 KZ650 (Complete!)
1979 KZ650 SR (Sold!)
1979 KL250 (For sale)
1994 Bayou 400 (four wheel peel )
Replied by N0NB on topic Thank You APE ! ! !
Long time no see, Corey.
Looks like you've got a nice 550 going. How's the racin' going?
Nate
- CoreyClough
- GPz550 Addiction
16 Mar 2010 17:01 - 16 Mar 2010 17:01 #353918
by CoreyClough
Mark,
Air passages around the port? Care to elaborate on that? I'll have to look into the drilling the fins mod too.
Thanks NONB,
I start racing next month with AFM, missing the first round at Buttonwillow this weekend, but I'll be spectating(crying). I hope to do the remaining 6 alternating rounds at Infineon(never had any wheels on that track), and Thunderhill. I have a lot to learn still, but am jumping in before I get too old. :blink:
Been busy Admining the GPz550 Site. I check in every once in a while.
Thanks NONB,
Last edit: 16 Mar 2010 17:01 by CoreyClough.
- mark1122
- Keep twisting it
17 Mar 2010 08:10 #354013
by mark1122
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
CoreyClough wrote:
You see the little bit of slag around the chin well, just below the surface?
That is the stuff im talking about. it dosnt hurt in this area, but u want to look all over the head. any slag that will deter air flow, especially around the xht ports leading into the inner parts of the head, around the fins and plugs.
I'll see if i can find some pics of the fins drilled for u. this was common on the kz900/1000 race bikes. dont know about the 550's, but the principle is the same. it helps the air take the heat away from the fins faster.Pops yosh did it. he even drilled a bit of a hole into the top around the chamber, but i would not do that.he had a free supply of heads.u dont need to go crazy, unless u find u have a heat issue. with stock compression u will be fine.
Head Surface Step
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- CoreyClough
- GPz550 Addiction
17 Mar 2010 20:10 #354157
by CoreyClough
I'd like to see that Mark. Thanks for the advice.
I have been getting oil in the pan temps around 240F with the stock oil cooler out on track. I posted about this here somewhere. I'm using a Daytona Digital Temperature Gauge. Eventually I'll instal a Zephyr ZR550 Oil Cooler I've had for a while. It's bigger and with a little frame modification(a few new holes) it should cool much better. Uses the same oil pan as the KZ and GPz550.
- turboguzzi
- Thank you received: 72
21 Mar 2010 09:40 #355165
by turboguzzi
Replied by turboguzzi on topic Thank You APE ! ! !
hi correy
some nice stuff in the pics, your bike is really inspiring.
Let us know what kind of HP you get with all that stuff thrown in. You started @ 55hp with not that much work right?
Cheers
TG
Cheers
TG
