550 shim tool
- shizzomynizzo
Is the motion pro tool the same one that I need?
Or if anyone can provide a link, it would be appreciated.
Thanks
24 hours in a day...24 beers in a case
1981 KZ550 ***SOLD***
1982 KZ1100 A2
- Thank you received: 2098
I'm about to check clearances on my 81 550. I know I will need a special tool to change the shims. I can only find tools for other bikes (750-1000cc models)
Thanks
'81KZ550 has shims located under the bucket (under bucket shims), which requires cam shaft removal to access the shims.
The shim is "hidden" underneath the bucket, whereby the bucket must be removed to access the shim.
The MotionPro "batwing" tool (or Kawasaki "special" tool), is used when changing shims located on top of the bucket (over bucket shims), where the shims are visible under the cam lobe, and where cam removal isn't necessary to access the shims.
The tool holds the bucket down allowing space between the shim and cam lobe so the shim may be removed and replaced.
Click > www.z1enterprises.com/detail.aspx?ID=152
which includes the following information:
Shim Changing tool - Motion Pro for Kawasaki
MP08-0019
Used to replace shims on Kawasaki Z1 KZ900 KZ1000 KZ1100 KL600 KL650 KLX650 KZ1300 ZN1300 KZ750 (twin)
Removing and replacing the cam shafts is a very exacting procedure, fraught with dangers of stripping cam bolt holes and bending valves due to incorrect reassembly of cam chain and cam sprockets.
Would urge using and closely following an FSM, and studying the several KZR articles previously posted on the subject.
Could be that the clearances are within specs without needing any shim changes.
- CoreyClough
- GPz550 Addiction
- Thank you received: 80
I use a 0.10 mm (.004") and a 0.20 mm (.008) blades to check the intakes. Exhaust, I use the 0.15 mm (.006") and 0.25 mm (0.10"), and if the smaller goes in, but the larger doesn't it's within specs for the 550, and I wouldn't change the shim if you're within. I do like to check with the remaining blades in between, just to see what the actual gap is, but with my experience changing shims, if it's not at the high or low measurement, I leave it. Measure, loosen the tensioner, zip tie the chain to the gears, remove cam, change shim, reinstall cam, do the same to the other cam if needed, tighten the tensioner, rotate engine a few times, recheck. . . See how much is involved, to try to get a closer clearance?
A noisy valve is a happy valve.
Use a magnet to remove the buckets, or work them slowly and carefully with a pair of needle-nosed vice grips. Twisting them slightly, before removing them if the buckets seem to be stuck.
Zip-tie the cams to the chain when removing one cam at a time, and mark the cam and chain where they meet with a little "white-out", just in case.
Loosen the cam chain tensioner, but don't rotate the engine with it loose. This makes getting the cams out and back in easier.
This, of course, is just some suggestions, and always work for me.
'85 GPz550(ZX550-A2)
- shizzomynizzo
I knew the process was a little more tedious compared to the honda I have, but I didn't expect that.
Hopefully they are all within spec!
I take it I do not need a tool to remove them once the cams are out?
Thanks again
1982 KZ1100 A2
- timebomb33
- Thank you received: 10
I THINK MY POWERBAND BROKE
- loudhvx
- Thank you received: 1616
Here are some important things to note:
#1 DO NOT REINSTALL THE VALVE COVER WITH TENSION ON THE CAM CHAIN. MAKE SURE THE TENSIONER IS RELEASED.
#2 It is way easier to reinstall the cams with the tach drive shaft removed. It is real easy to mess up a camshaft if you don't.
#3 Make sure you take a lot of time and patience when reinstalling the cams. If things start to bind and it seems as if the cams don't want to sit down in place as you tighten the cam caps, START OVER. Take a little more time now, or spend a lot more time and money later.
#4 Make sure all of the cam cap screw holes are cleaned out completely. No oil or sealant in the holes. Use a piece of paper towel rolled into a wick to absorb the oil. Oil and sealant don't compress, but they feel slippery and/or spongy which leads you to strip threads with little torque. This is probably the main reason for stripped cam cap bolts. (Even more so for the valve cover bolts. Get every bit of sealant out of those bolt holes! It's a pain, but way, way easier than retapping and installing helicoils.)
#5 Keep everything spotlessly clean, Especially when handling buckets and replacing shims. A piece of dirt can totally mess up the new clearances.
#6 The cam sprocket bolts are held in with locktight. Lay some paper towels around so the locktight crumbs don't fall into the motor. Clean all of the bolt threads with a wire brush to get all of the locktight off.
#7 Stay organized. Use egg cartons or some such to keep the parts arranged for each cylinder. Do not mix buckets, they are not 100% interchangeable. Some will swap, some won't depending on tolerances. And most importantly write down everything! Keep a legible record of every clearance (1 to 4 intake and exhaust.) Also write down every shim thickness as you pull it. (You probably want to get a good micrometer or at least a good caliper and practice reading it if you are new to it.)
Here is a link to a bunch of important cam-timing info for the 550's:
(Corey and I spent days getting this info together).
home.comcast.net/~loudgpz/GPZweb/CamsKZZ...KZZXZR550500400.html
Personally, I prefer the shim-under arrangement. The first time will take seemingly forever because it's a learning curve. Short cuts always result in more time later. By the second or third adjustment you'll beable to do the whole thing in an afternoon. (Because you will keep a record of every shim and clearance so you'll know what shims to order before you do it next time.)
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
- CoreyClough
- GPz550 Addiction
I highly recommend NOT removing the gears from the camshafts unless you absolutely have to.
Here's one for suggestion #3. Binding Camshaft:
Yes, if it's binding, it's not lined up. :S No worries, I grabbed another camshaft.
- loudhvx
1981 KZ550 D1 gpz.
Other links.
- CoreyClough
- GPz550 Addiction
Ride it to CA and I'll show you.
- shizzomynizzo
1982 KZ1100 A2
