air cut off switch
- mastermudd
- MFolks
- Thank you received: 540
There are reed valves under the covers that have two rubber hoses connected to this air valve. Most riders have removed this sytem and blocked off the valves with machined plates available from several sources.
Myself,I'm going to remove my bikes CASS when the weather gets warmer. I ordered the kit from www.tpoparts.com # TPOHRSMOG. It comes with two block off plates,screws,vinyl caps and instructions.
- loudhvx
- Thank you received: 1616
Usually the first symptom of it going bad is big back fires when you close the throttle.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
- davel
It injects air into the exhaust. This doesn't really affect combustion or running since it only affects burning outside of the combustion chamber.
Though it does reduce cylinder filling by decreasing the scavenging of the cylinder. When the CASS is operating, low pressure in the exhaust pulls fresh air in through the reed valves rather than spent gasses from the cylinder. Not desirable in a high performance application.
- timebomb33
- Thank you received: 10
I THINK MY POWERBAND BROKE
- larrycavan
- Visitor
There's a crank case scavanging affect that is a plus for for the clean air system. Everybody bails out on it and forgets about that benfit.
- loudhvx
1981 KZ550 D1 gpz.
Other links.
- Bluemeanie
- Thank you received: 14
- mastermudd
- Thank you received: 2098
bluemeanie that is exactly what i'm looking at on my 1100. never seen anything like it. i appreciate everyones response. my bike does backfire when i let off the throttle, i assumed it was running to rich. this may offer another explanation.
Sometimes, slight enrichment of the pilot circuit will reduce exhaust popping while decelerating with throttle closed.
Whereas, a leaner pilot circuit may increase the popping.
- larrycavan
- Visitor
When that happens you can generally trace it to one of the vacuum hoses that connect the air valve to the intake boots.
Rarely do those valves every go bad. At least they didn't used to :laugh:
It's possible to fabricate a connection to the crankcase breather with the airbox removed to help scavange it.
What's it buy you?
That depends on the motor. On a stocker, not much. On a motor that's been significantly increased in cc, it would be more beneficial.
