550 noise in bottom end
  • Shoe48
  • Topic Author
  • Live each day as it is your last
29 Mar 2006 17:45 #35298 by Shoe48
550 noise in bottom end was created by Shoe48
The noise sounds like a timing chain but that would have a automatic tentioner right ? anything else ?? It does not go away when warm stays about the same ,, Does the 550 use the Hy Vo ? chain ? its kinda annoying ? it not a rod or wrist pin I know that noise ... I cant spell tonight either ,, Shoeman :)
Post edited by: shoe48, at: 2006/03/29 20:46
  • lemo32
  • The Price of Cool aint cheap
29 Mar 2006 19:17 #35312 by lemo32
Replied by lemo32 on topic 550 noise in bottom end
not real familiar with the model but have found that you are your best guess. meaning that it does sound like cam chain.
1979 kz 1000 06 katana 750
  • tellietubbie
  • Visitor
30 Mar 2006 01:38 #35378 by tellietubbie
Replied by tellietubbie on topic 550 noise in bottom end
Shoeman, your 550 is almost identical to my 500 which is in LOTS of bits.I checked play on the primary chain and it needs replacing[>25mm].That may be your problem.
Just my 2 cents. Regards.
30 Mar 2006 14:17 #35489 by RomSpaceKnight
Replied by RomSpaceKnight on topic 550 noise in bottom end
My guess would be primary drive chain, if it has one. 650's went to gear drive at one point in time I believe. Real bad at low idle speed? Goes "away" faster than idle.
