- Thank you received: 1
starter clutch
- rosken
12 Mar 2010 11:14 #352926
by rosken
starter clutch was created by rosken
Hi all, i have the usual starter clutch problems, (i.e. slipping, whirring sound,) renewed the springs and rollers, still the same, striped it all again and replaced the cog that they grip on, still the same, replaced the starter and battery, still the same, so dam annoying! any one really know how to fix this?
thanks guys.
thanks guys.
- TeK9iNe
- What did you do!?!
- Thank you received: 28
12 Mar 2010 11:38 #352934
by TeK9iNe
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Replied by TeK9iNe on topic starter clutch
The slipping/whirring sound...
is it durring starting? or after starting/while running?
You can check the starter clutch by hand with the cover off. You should be able to turn the clutch counter-clockwise and it should grab and turn the engine over constantly. When you turn it clockwise, it should drag slightly and no longer grab the engine.
If you are using a really slick synth oil, it can cause starter clutch slipping issues when the clutch gear shaft gets worn/galled.
Replace all contact surfaces and make sure everything is assembled exact, or...
Rough up all the rollers and gear shaft with some 150+ sandpaper, using horizontal motions only, not around them but along thier length.
That should do it for you.
GL.
GL.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- Kawickrice
- Thank you received: 18
12 Mar 2010 12:16 #352937
by Kawickrice
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
Replied by Kawickrice on topic starter clutch
What kind of bike you got?
73 Kawasaki Z1
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
- rosken
15 Mar 2010 10:06 #353609
by rosken
Replied by rosken on topic starter clutch
z650c3
- rosken
15 Mar 2010 10:10 #353612
by rosken
yes it does catch one way and turn free the other, i will try roughing the rollers with sandpaper, thanks.
