- Thank you received: 1
750-4 valve shim swap anyone?
- polkat
08 Mar 2010 23:50 #352129
by polkat
750-4 valve shim swap anyone? was created by polkat
I need the following valve shims for my 750 four....
Three at-2.45mm and one at-2.40mm.
Send me these and I'll send you back....
Two at-2.55mm, one at-2.60mm, and one at-2.65mm.
PM me here if you have these, thanks!
- otakar
09 Mar 2010 06:06 #352161
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
Replied by otakar on topic 750-4 valve shim swap anyone?
Do you have any 29mm shims to trade for the 13mm shims you want?
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- Link14
- Thank you received: 6
09 Mar 2010 06:50 #352165
by Link14
Replied by Link14 on topic 750-4 valve shim swap anyone?
I'll check when I get home tonight polkat
- polkat
09 Mar 2010 12:02 #352223
by polkat
Replied by polkat on topic 750-4 valve shim swap anyone?
Thanks Link14!
otakar, I have to admit that I don't know what a 29mm shim is. Is that the diameter? If so, no I don't have any.
- Link14
09 Mar 2010 17:51 #352308
by Link14
Sorry polkat, only have 1-2.45mm. My others are 2 x 2.55mm, and 1- 2.60mm.
If you want it, pm me.
- staniel
- Thank you received: 5
23 Aug 2010 10:08 #393229
by staniel
1983 KZ750 L3 with 4-1 Kerker pipe and pods
1983 KZ750 L3 parts bike
Replied by staniel on topic 750-4 valve shim swap anyone?
Howdy, folks!
It's valve clearance time for my KZ750L3, which uses little under-bucket shims (parts number 92025...).
I've got
2x 260
2x 250
I need
2x 240
2x 235
1x 230
1x 225
(I'm getting a couple extras for the zero-clearance valves I have)
I've got
2x 260
2x 250
I need
2x 240
2x 235
1x 230
1x 225
- Motor Head
- Thank you received: 391
23 Aug 2010 10:15 #393231
by Motor Head
Replied by Motor Head on topic 750-4 valve shim swap anyone?
This is a good price for this kit, best I've seen this year anyway.
www.z1enterprises.com/detail.aspx?ID=1852
It will have the shims for this and the next few adjustments, worth it in the long run.
- staniel
23 Aug 2010 12:33 #393247
by staniel
That set seems like a strange thing. It's $100 for 20 shims, with almost none of the xx5 sizes.. That's $5 apiece, where each shim is $4 on the same site! Why get the kit?
- Motor Head
23 Aug 2010 12:36 - 23 Aug 2010 12:50 #393249
by Motor Head
Look how much for the organizing box and you will understand. If you need some other goodies like filters, fork oil, etc I usually try to fill up on some basics when I order.
EDIT: I see your in Seattle area, why don't you post a wanted on the CL there? Big bike city and someone might have what you need.
Last edit: 23 Aug 2010 12:50 by Motor Head. Reason: Edit
- staniel
04 Sep 2010 10:37 #396053
by staniel
Thanks for the suggestion. No one responded to my CL ad, and the kawi dealer won't trade old ones for new, so I'm gonna have to buy 5 shims, install, re-measure and cross my fingers.
Good news is that if some of them are the wrong size, the shop will trade me for the ones I just bought from them.
