Clutch cable? 550 LTD
- intrepid7
08 Mar 2010 23:01 #352128
by intrepid7
Clutch cable? 550 LTD was created by intrepid7
Any info on replacing clutch cable on 1982 550LTD appreciated. Does it go into the motor or can it be disconnected from the outside? Thanks
- JMKZHI
- Thank you received: 48
09 Mar 2010 08:25 #352178
by JMKZHI
Replied by JMKZHI on topic Clutch cable? 550 LTD
You'll need to remove the left side engine sprocket/chain cover - no big deal. Doing so typically requires the removal of a footpeg, the toe shifter & the starter cover. A manual would be helpful.
