Fresh built KZ900 blows low compression ??
- cuddies say yee 925
08 Mar 2010 21:42
Hey,
I'll try to make it short. I rebuilt the motor, and it probably has about 45 minutes RUN time, none of that has been ridden. Most is just idle and trying to get it tuned. I can never get the thing to run right. It's been about 6 months sinced I've worked on it, because I lost all my patience with it and am now ready to start working on it again. Before I parked it last, I did a compression test and read as follows, in order of cylinder 1-4: 20psi, 0psi, 120psi, 120psi. I have no clue why it blows such low compression, and really am lost as to why cylinder 2 can blow 0 psi. It's not a wrong reading, I did it multiple times. It's a good guage too, there is no fault there. It never actually ran on all 4 cylinders, had a rough idle and only ran on 2 cylinders, the higher I revved it the other two would kick in and start to work.
And ideas as to where I should start looking and/or testing?
- APE Jay
Re: Fresh built KZ900 blows low compression ??
08 Mar 2010 22:12
Sounds like you have valves not closing. Do a leakdown test.
- Mcdroid
- Gone Kwackers
09 Mar 2010 03:00
APE Jay wrote:
Jay has it pegged (who could expect less?
) What do you mean by 'rebuilt the motor'? What did you do?
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
09 Mar 2010 03:38 - 09 Mar 2010 03:50
cuddies say yee 925 wrote:
If not already done, would start by assuring all valve clearances are within specs.
Hopefully, good seating of each valve was checked and no valves got bent during reassembly.
Hey,
Last edit: 09 Mar 2010 03:50 by Patton.
- PLUMMEN
09 Mar 2010 05:15
definately check valves,what was done on rebuild?
09 Mar 2010 11:51
No, there are no bent valves. Motor has 6,600 original miles, then my dad parked it for 20 years. Motor was locked up from sitting, so it got torn down. I didn't touch the bottom end at all, and top end has stock replacement pistons, stock rings, and fresh head. I did all the work myself and am very confident in it. I never could get the exact valve clearances, but they were always very very close. Maybe a ring cracked or something. I will have to wait to see, it has to be torn down again no matter what
- TeK9iNe
- What did you do!?!
09 Mar 2010 12:20
Even with a cracked ring, or no ring for that matter, you'll have better than 0 compression!
Deffinately already solved... Valves are not closing correctly, if at all!
Or you forgot to install the head gasket... :laugh:
kidding.
GL.
kidding.
GL.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
09 Mar 2010 12:25
Exactly! That's why I don't know HOW # 2 is blowing 0 psi.
09 Mar 2010 16:26 - 09 Mar 2010 16:27
Perhaps cam timing was incorrectly performed on reassembly.
Last edit: 09 Mar 2010 16:27 by Patton.
