CYLINDER BASE GASKET SEALANT PROCEDURE
- JOHN LUCAS
08 Mar 2010 10:28 #351971
by JOHN LUCAS
CYLINDER BASE GASKET SEALANT PROCEDURE was created by JOHN LUCAS
The manual says to apply silicone to the rear inner stud base area. Why just there and not the front (ex side)too?
Any guidence would be appreciated -1980 KZ1000 LTD
Thanks
John
Thanks
John
- timebomb33
- Thank you received: 10
08 Mar 2010 10:44 #351976
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic CYLINDER BASE GASKET SEALANT PROCEDURE
i never use any sealant of any kind myself it makes it easier to remove for the next guy.
- bountyhunter
- Thank you received: 337
08 Mar 2010 10:49 #351979
by bountyhunter
Replied by bountyhunter on topic CYLINDER BASE GASKET SEALANT PROCEDURE
JOHN LUCAS wrote:
My guess would be that's the area where the oil pass through going up into the head is, but that's just a guess. If they say use it, I would use it. Something like 3-bond or some good sealant.The manual says to apply silicone to the rear inner stud base area. Why just there and not the front (ex side)too?
Thanks
John
- mark1122
- Keep twisting it
- Thank you received: 109
11 Mar 2010 08:04 #352650
by mark1122
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Replied by mark1122 on topic CYLINDER BASE GASKET SEALANT PROCEDURE
I have wonder about this myself. the oil passes up the outer rear studs, so why would Kawi say to seal the inner rears? the only thing that i can think of is, possibly the oil has a habit of creeping by the O ring around the cam chain galley under the head, in this area, and then fills the stud cavity? it still doesn’t make sense, since there would be no pressure there.
if u feel the need to silicone somewhere, i would do the outer rear seals. this is where i find they leak. also it is a good idea to have the cases and blocks, mating surfaces, milled for trueness, if u have a constant leak issue. they have been known to be out of true.
Hope this is helpfull.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
