Sounds from clutch area
- BIGD
07 Mar 2010 20:02 #351870
by BIGD
Had 1981 KZ1000 M1 From 1981-1995 Canadian Model
Have 1981 KZ1000 M1 US Model
Sounds from clutch area was created by BIGD
Not quite sure how to explain what is happening, BUT a noise is coming from the the area that houses the clutch assembly. I seem to get a drop in RPM followed by a grabbing sound from the clutch area. A variety of problems have crossed my mind including, something wrong in the clutch area, poor timing, gas being interrupted somehow to cause the drop in RPM's(not sure about that one). I do not have a problem fixing most anything on my bike, but have not experienced anything like this. It does not stop me from riding, but at a stop light I think it feels like it will stall, then the sounds start from the clutch area. This is not a starter clutch problem as this was just recently replaced. Thanks for any help. Don
- TeK9iNe
- What did you do!?!
- Thank you received: 28
07 Mar 2010 20:48 #351878
by TeK9iNe
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Replied by TeK9iNe on topic Sounds from clutch area
Well... sounds like you're tearing into that clutch area
Put the bike on its side stand (so the oil won't dump out), and pull the clutch cover off.
Good luck.
Good luck.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- MFolks
- Thank you received: 540
07 Mar 2010 21:13 #351887
by MFolks
Replied by MFolks on topic Sounds from clutch area
Original clutch on the bike? Might be time for a new one.
Previously owned bike? No idea of abuse like burn outs?
