- Thank you received: 5
Clutch drag on 82 KZ750-R1 (GPz)
- ELCouz
The clutch is slipping with the handle released!!
Must be something cheesy with the clutch!
1982 KZ810-R1 GPZ with hindle 4-into-1 pipe
- Thank you received: 2098
Bad news guys ... it doesn't help it's worse!
To review ---
At first the clutch was dragging even with the lever squeezed all the way in against the handlebar grip, there being insufficient adjustment available at the handlebar screw.
And now, after additional cable adjustment at mid-sheath, the clutch is now slipping with zero squeeze on the lever.
Perhaps too much cable sheath adjustment was made, whereby the inner cable (initially too long) is now too short in relation to the sheath length.
Presently, when the hand lever's squeezed, is there slight cable motion before requiring the normal stronger grip squeeze needed to disengage (separate) the clutch plates?
Or does the lever feel normal, but the clutch slips while riding?
In other words, does squeezing the lever feel like it's separating the clutch plates? And does releasing the lever feel normal except for a slipping clutch?
It might be time to perform a clutch pushrod adjustment. But even a perfect pushrod gap may be thwarted by improper cable adjustment.
- ELCouz
Exactly! _BUT_ even if the cable is pulled a little bit more clutch will slip BUT i should be able to correctly engage first without hearing the gears grinding together (just my 2 cents)!!!
it might be time to perform a clutch pushrod adjustment.
Could you help me locate (or what it looks like) what is the clutch pushrod?
Someone once told me that it's the steel plates but i'm not sure...
What are you suggesting to do first?
I love some much this bike but i'm afraid each time i shift i wear the gears more than normal use!
Laurent
The oil is cold and thick, and the plates are "sticking" together.
...What are you suggesting to do first?....
Assure the clutch cable itself is properly adjusted.
Ride the bike far enough to thoroughly warm up the engine (several miles).
Come to a stop, and then shift down into low gear.
Let us know what happens.
Also let us know whether or not the clutch seems to be slipping or functioning normally while riding the bike.
- Old Man Rock
- Thank you received: 225
This is for the KZ900 & 1000 series....
Top right corner...
Now if I'm whacked on this due to don't have a manual for your bike so sorry....
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- ELCouz
Alright i will try that tomorrow.. because the hindle muffler 4 into 1 that came with it has been modified to be straight for racing (With baffle removed, this will not pass the inspection test!) OMG so much noise my neighbors would hate me especially at night!
I've read on a forum that people put a mix ATF oil with their engine oil to eliminate the clunk and sticky clutch problem.
Keep you informed tomorrow!
Best Regards,
Laurent
- ELCouz
- Old Man Rock
This goes in conjunction with the cable adjustments....
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
...I've read on a forum that people put a mix ATF oil with their engine oil to eliminate the clunk and sticky clutch problem....
A seized engine will certainly eliminate the clunk and further worry about sticky clutches. :woohoo:
:laugh: :laugh: :laugh:
- ELCouz
Then... all you need to worry is how to pay the towing :lol:A seized engine will certainly eliminate the clunk and further worry about sticky clutches.
I guess some people try desperately everything that comes in their mind
Laurent
- Link14
- Thank you received: 6
