Got the cylinder back on
06 Mar 2010 11:34 #351580 by fordtruck
Got the cylinder back on was created by fordtruck
We got the cylinder back on this morning. Sorry I don't have any pics, my camera battery died.
Thanks for all the great advice you guys gave to me. Here is how I got it done.
I made wooden piston supports just like the manual says. The only difference is I made my 6" long instead of 4". I put the supports under the center two pistons and turned the crankshaft until they were resting on the supports. At first I tried using my fingers to compress the rings, but that got my nowhere fast! I then switched to popsicle sticks. Someone else on here said it first, but popsicle sticks were made to install rings in cylinders! My Dad and I took our time and when back and forth between pistons. We installed one ring at a time.
Once the center two pistons were in, we shoved the cylinder down and started on the outer pistons. The outer pistons went much faster. Partly because we had figured out what we were doing by then, and also they are easier to get to.
Now I'm going to grab a cold one, stare at my bike, and dream of the day that it roars to life again!
'77 KZ1000-MTC 1075 kit. Stage 1 port
  • Becker
  • The Doctor Will Rise Again
06 Mar 2010 11:40 #351582 by Becker
Replied by Becker on topic Got the cylinder back on
I like your style.
I'm sorry but your gonna have to explain that one to me. How do you use popsicle sticks to put rings in??
78 KZ750B3
79 KZ400 LTD
78 KZ650C2
79 KZ650C3
78 KZ650B2A
80 KZ650F1
80 KZ650E1
81 CB750K Super Sport
06 Mar 2010 12:19 #351586 by sbc1320
Replied by sbc1320 on topic Got the cylinder back on
I am the one that said to use popsicle sticks. I think someone laughed when I first said it months ago. The 4" wooden supports will work, but they will be short if the motor is on the wrong stroke. Stick the supports in from the front and if they are short, remove them and turn the motor over again until the rods go the other side of the crank. Don't matter in your case as you already made some longer ones. With the beveled edge or chamfered edge at the bottom of the cylinder, it acts like a funnel and you don't really need ring compressors. A lot of regular ring compressors can't be used anyways. Just got to walk or rock the cylinder over one ring on one side and then go to the other side. Didn't take me long to do mine and all went well. Too bad I sold the bike today and it went to Mississippi. Good luck with your project. I think someone else said chopsticks, doesn't matter wood or plastic. Just don't want to use metal objects as you might scratch the rings.
1980 KZ1000 LTD-B4(MK II engine) - Progressive suspension, MTC pistons, Dynojet Stage III, all wear items replaced, WFO paint scheme(1978), etc..
Past bikes- 2 1976 Kz900's, 5 1975-76 Honda CB750's, Honda 500 -4, Honda 250, Honda 125, Honda 100, Suzuki RM 250, Honda XL350, Kawasaki KLR 650, etc..
06 Mar 2010 14:12 #351591 by fordtruck
Replied by fordtruck on topic Got the cylinder back on
I'm sorry but your gonna have to explain that one to me. How do you use popsicle sticks to put rings in??[/quote]
I used the sticks to press the rings into their grooves to allow the cylinder to slide over them. My Dad would take one popsicle stick and press the ring 180 degrees from the gap. I would then use two sticks to press on either side of the gap. It worked like a charm!
  • Becker
06 Mar 2010 14:20 #351592 by Becker
Ahhh... I get it now. That makes sense.
78 KZ750B3
79 KZ400 LTD
78 KZ650C2
79 KZ650C3
78 KZ650B2A
80 KZ650F1
80 KZ650E1
06 Mar 2010 14:32 #351598 by keith1
Replied by keith1 on topic Got the cylinder back on
sweet.....you are on your way......
06 Mar 2010 16:53 #351627 by APE Jay
Replied by APE Jay on topic Got the cylinder back on
Popcycle sticks were invented for installing piston rings. People don't believe me. :laugh:
06 Mar 2010 19:22 #351668 by timebomb33
Replied by timebomb33 on topic Got the cylinder back on
the reason i like to use chop sticks is they are longer and its easier to get in around the cylinder stud with them also they dont come apart like popsicle sticks sometimes do.
I THINK MY POWERBAND BROKE
07 Mar 2010 05:37 #351698 by KZ1100 Bully
Replied by KZ1100 Bully on topic Got the cylinder back on
I used chop sticks yesterday, worked great.
1983 Kawasaki KZ1100 Spectre D2
07 Mar 2010 14:24 - 07 Mar 2010 14:25 #351788 by fordtruck
Better late than never. Here's the pics
Last edit: 07 Mar 2010 14:25 by fordtruck.
07 Mar 2010 14:26 #351789 by fordtruck
07 Mar 2010 16:40 #351814 by Link14
Replied by Link14 on topic Got the cylinder back on
Nice clean looking install. Looking good!
