sounds from plugs or plug wires,normal?
- scubarod
03 Mar 2010 20:58 #351140
by scubarod
sounds from plugs or plug wires,normal? was created by scubarod
i can hear a spark coming from plugs or plug wires on my kzp.is that normal?i hear it when reving slightly and while riding.
- MFolks
- Thank you received: 540
03 Mar 2010 21:04 #351141
by MFolks
Replied by MFolks on topic sounds from plugs or plug wires,normal?
Probably time to replace both sparkplug caps and wires. What you're hearing is the high voltage going to ground(usually insulation break down causes this).
Some 7mm sparkplug wires from the local hot rod shop should fit. What came from the factory has/had resistors in the caps reducing the RFI(what makes radio's snap and crackle when the plugs fire).
- Thank you received: 2829
04 Mar 2010 06:11 #351197
by 650ed
Replied by 650ed on topic sounds from plugs or plug wires,normal?
Find a dark spot at night and run the engine. If the wires are leaking you will see blue going from the faulty wire(s) to ground. Ed
