- Thank you received: 25
Billet cam tensioner roller - Necessary?
- T_Dub
Heres a link to the think on Z1E, just in case I wasn't clear on the part I'm talking about.
www.z1enterprises.com/detail.aspx?ID=3991
1977 KZ650B1
-810cc
-Cavanaugh Racing Head
-Mikuni RS34's
-GPR Muffler
- mark1122
- Keep twisting it
- Thank you received: 109
If u used all Listka parts, u would no longer have any rubber damping in the system. Is It necessary? Cant say for sure.Kawi thought so.I would tend to agree.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- bill_wilcox100
- Thank you received: 5
I have never done this but... sounds to me that if the existing OEM sprocket is still good, it is worth keeping... not being metal I would think it is quieter, noticeably quieter? Don't know.
I'm sure others who have done this will be by to comment.
Best of success,
Bill
1977 KZ650-B1 (Stock)
Upgrades:
- Dyna S Electronic Ignition (DS2-2)
- Dyna 3 Ohm Coils (DC1-1)
- Coil Repowering Mod
- Progressive Springs Front & Rear
- Saddlemen Seat Cover
- New Metallic Red Re-Paint & Repro Badges.
Montreal, Canada
- T_Dub
1977 KZ650B1
-810cc
-Mikuni RS34's
-GPR Muffler
- bill_wilcox100
Best of success,
Bill
Upgrades:
Montreal, Canada
- Samwell
Hey guys, I just wanted to run something past you all. I've been debating the need of putting a liska cam chain tensioner roller in my engine. They're pretty costly, but if they're the best option by a long shot I'll probably put one in. So, opinions?
I've put all the liska parts in my machine. I had it apart anyway and the oem stuff was a little chewed up, so I went for it. The cam chain noise isn't much louder if any. But the top idler wheel is taller than oem so you can't slide the valve cover out sideways. It has to slide down the back of the block - after the carbs are off! A nuisance to be sure when it comes time to shim the valves!
- timebomb33
I THINK MY POWERBAND BROKE
- otakar
I did not even know that Liska made an Idler tower for the KZ650. I have not been able to find one.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
- APE Jay
- Banned
- Thank you received: 58
Jay
- saxjonz
- KawboyZ
- Thank you received: 76
Think about precision. I would imagine that when you rap the throttle that the timing will stay accurate as opposed to parts that give and take, especially if worn.
I will let you know later when I get it back together how it sounds and runs. I am pretty sure that it will function much better than the OEM did for my application. Every time you get in to it you open a can of worms. Improve this then you have to reinforce that and this that and the other thing and oh by the way this should be done too.
Stock may not be such a bad idea if you want to get some real miles out of your bike without too much trouble. Well, I don't know anything much except that when you open that can be ready for what happens next. You could have a stock bike and buy a new stock bike that really is fast and reliable in comparison to a built engine that overheats and is maintenance intensive. I would go back and leave it stock with maybe a little hotter cam, good carbs, pods and exhaust and call it a day. After all is said and done my bike with all the engine work will make me happy but still will be slower than a 600, or 750 from today. The amount of money I have in the engine I could have easily aquired a zx14 that would absolutely smoke the kz as if it were a little 250.
79 LTD B3
