- Thank you received: 7
how to measure timing chain advice
- toad
thanks
Toad
78 kz 1000
wiesco 1015
29mm smoothbores
gs1100 swingarm
gsxr rear
- T_Dub
- Thank you received: 25
1977 KZ650B1
-810cc
-Cavanaugh Racing Head
-Mikuni RS34's
-GPR Muffler
- Thank you received: 2098
ok I have checked all of my timing chain components and looks like the only one I need to replace is the cam chain tensioner assembly (rubber roller) is chewed up a bit,so I would like to measure my timing chain but in the manual I cannot find a spec for it,I really dont want to replace it if there is no need to do so, and I'm not splitting the cases at this time.Does anyone no how to check for wear?
thanks
Toad
@ 5kg taut, 20 link length pin to pin standard spec is 155.48mm~155.71mm with service limit 157.8mm.
- toad
thats wierd, I measured it and from pin to pin I am only 148.71, I checked 3 times that my vernier was centered @ 20 pins.
78 kz 1000
wiesco 1015
29mm smoothbores
gs1100 swingarm
gsxr rear
- timebomb33
- Thank you received: 10
I THINK MY POWERBAND BROKE
Awesome thanks for the quick reply,much appreciated
TB is correct as to needing a 20 link count.
19 @ 148.71mm extrapolates to 20 @ 156.54mm, so believing you're within 157.8mm service limit.
The diagram below is for omr, after removing his boots. :lol:
[Click on image to hear the counting.]
