- Thank you received: 1
APE gearbox bearings
- Ktm181
- Man made it, so Man can fix it
03 Mar 2010 00:12 #350963
by Ktm181
APE gearbox bearings was created by Ktm181
Hello Gents, hope you can answer this for me, I have been looking at buying gearbox bearings from APE but cannot understand which bearing is which, I will be wanting one input shaft bearing and one output shaft bearing, has anyone used these and can anyone advise which part number is which? YES, i tried APE via email but have had no reply twice now! I might also try the shift shaft, what do you guys think?
HELP!
Thanks heaps,
Kt
HELP!
Thanks heaps,
Kt
- Samwell
03 Mar 2010 02:38 #350970
by Samwell
Replied by Samwell on topic APE gearbox bearings
Ktm181 wrote:
If you've got any concerns about your shift shaft, then by all means replace. Since you're in the transmission, you might as well do it right. Its in the the $30 range, that's impulse buying range! As for your bearings, call them up and ask. I've called about a few things and gotten good results. If the person who answers doesn't know, they get the one who does and problem solved.
HELP!
Thanks heaps,
Kt
- Ktm181
03 Mar 2010 17:48 #351100
by Ktm181
Replied by Ktm181 on topic APE gearbox bearings
thanks for the reply. bit hard to ring as i am in Australia, oh well might have to try a further email direct to Jay at APE.
KT
KT
