- Thank you received: 7
broken tachometer cable guide advice
- toad
78 kz 1000
wiesco 1015
29mm smoothbores
gs1100 swingarm
gsxr rear
- keith1
- Thank you received: 2
- Thank you received: 2829
Until what broke in half; the cylinder head or the tach cable guide?
- Thank you received: 2098
KZ900-B1 has the version listed at Z1E.
Am unaware of whether the versions are interchangeable.
Description: GUIDE,TACHOMETER GEAR
Package Quantity: 1
Item Status Code: Active
[Click on image to enhance view]
Just guessing.
- beefsquasher
-Dave
1977 KZ1000 Mutt - 1075, Kenny Harmon Cams .400", RS34, Kerker, Dyna S
1997 Honda XR250R
1977 Yamaha XS360
1972 BMW R60/5
...went to unscrew the tach cable guide and it broke right in half....
Unscrew?? :S
Am thinking the guide (with o-ring) simply pushes into the head and then held in position by part 29.
- Ktm181
- Man made it, so Man can fix it
- Thank you received: 1
cheers,
Kt
- toad
78 kz 1000
wiesco 1015
29mm smoothbores
gs1100 swingarm
gsxr rear
- toad
thanks all!
78 kz 1000
wiesco 1015
29mm smoothbores
gs1100 swingarm
gsxr rear
