- Thank you received: 3
What can a 650 I-4 be punched out too?
- Dave Sloan
04 Mar 2010 00:37 #351162
by Dave Sloan
Z650B2 - Injected
Replied by Dave Sloan on topic What can a 650 I-4 be punched out too?
unfortunatly air cooled 750s dont have 6 gears only the 550s and later watercooled gpz750/900s
Z650B2 - Injected
- Tyler
- Thank you received: 92
04 Mar 2010 08:57 #351228
by Tyler
"74 Yamaha DT 400 Enduro
Replied by Tyler on topic What can a 650 I-4 be punched out too?
Its my understanding that the 6 speed internals can be installed in a 650 case, however the kick start is removed. Several people have done that one on this site.
- APE Jay
- Banned
- Thank you received: 58
06 Mar 2010 17:01 #351628
by APE Jay
Replied by APE Jay on topic What can a 650 I-4 be punched out too?
Injected wrote:
If the crank was stock, how did that increase the stroke 6 mm?
We used to do the 880 kits for one of the turbo tuners. Don't know if this would fit in a 650 block.
Jay
The bore was 73mm (+11) and stroke was increased to 60mm (+6) but it was for racing only. I believe the crank was stock but used longer rods and a spacer plate under the barrel. The motor was in a 650 chassis.
Jay
