6mm Cam Cover Bolt Stripped
- KENN317
01 Mar 2010 05:29 #350694
by KENN317
6mm Cam Cover Bolt Stripped was created by KENN317
I have a 1977 kz1000, 4 into 1 unknown exhaust pod filters. The bike had a leaking head gasket which I fixed, While attempted to put the cams back on I noticed that the Cam Cap Bolt would just spin. After I took the bolts out I noticed what appeared to be Heli coils on some of the bolts. Will Heli coils hold the cams in place or should I redo and use Time Sert or Keensert. I want to put the bike back together as cheap as possible, and Time serts and Keen serts are very expensive. Please advise
- 9am53
- homebrew, and some bbq
- Thank you received: 3
01 Mar 2010 05:31 #350695
by 9am53
'84 GPz900r
'71 CB350
s289.photobucket.com/albums/ll231/9am53/
Replied by 9am53 on topic 6mm Cam Cover Bolt Stripped
I just put a couple helicoils into my cam towers, but I don;t know how they will be holding yet, they seem good now.
'84 GPz900r
'71 CB350
- Thank you received: 2236
01 Mar 2010 05:53 #350696
by TexasKZ
Replied by TexasKZ on topic 6mm Cam Cover Bolt Stripped
Welcome Kenn317,
This topic has been discussed at length. Use the search function. Search "cam holder bolts" and "cam tower bolts." Otherwise, you can go to the Engine section and seach manually, if you have lots of time.
- Mcdroid
- Gone Kwackers
- Thank you received: 317
01 Mar 2010 06:03 #350697
by Mcdroid
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Replied by Mcdroid on topic 6mm Cam Cover Bolt Stripped
I second TexasKZ...this has repeatedly been discussed on this site...however, my personal choice is to replace the ruined helicoil threads with BigSerts (6mm TimeSerts are now too small to fit into the helicoiled holes)...which are specifically designed to redo Helicoils that have failed. This has been discussed on this site. I prefer TimeSerts/BigSerts over Helicoils...but others will disagree
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- KENN317
01 Mar 2010 06:09 #350699
by KENN317
Replied by KENN317 on topic 6mm Cam Cover Bolt Stripped
Sorry guys......for being lazy I guess. Kind of new to this site, should've looked up. I knew I could get a fast response by posting a question. I didn't think. You guys are the best!!
- Mcdroid
- Gone Kwackers
01 Mar 2010 06:17 #350701
by Mcdroid
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
If you can't locate the previous threads, we'll give you a hand...the info is here, you just have to mine for it... :laugh:
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
