Best degreaser for aluminum engines?
  • polkat
  • polkat's Avatar Topic Author
28 Feb 2010 16:53
#350616
Most old Kawa's get pretty grimy from road crap around the engine. If it were a car engine, I'd just coat it up with Gunk degreaser, scrub it a bit and hose it off. But Gunk and similar degreasers warn not to use on aluminum (as well as oven cleaner). I've tried aluminum wheel cleaners with no success, and I can't afford any kind of blasting. So what's out there that's safe for aluminum? Thanks!
  • otakar
  • otakar's Avatar
Re: Best degreaser for aluminum engines?
28 Feb 2010 17:11
#350619
I have used Gunk Foamy engine cleaner for years without problem. Never harmed the engine. I also use Zep Citrus cleaner which I buy at Home Depot and it works equally well The nice part about that is that it is 100% biodegradable and won't harm your grass when you pressure wash or hose off the engine.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
  • KLD
  • KLD's Avatar
01 Mar 2010 10:47 - 01 Mar 2010 10:47
#350729
Only thing I ever use is gas.
Last edit: 01 Mar 2010 10:47 by KLD.
01 Mar 2010 11:13
#350730
S100 works well for me.
Water based.
Okay to douse entire bike. Won't harm any finish. Hose off.
Click here > S100
Good Fortune! :)
  • shizzomynizzo
  • shizzomynizzo's Avatar
01 Mar 2010 11:16
#350731
I've used simple green with good results. It is biodegradable as well.
24 hours in a day...24 beers in a case
1981 KZ550 ***SOLD***
1982 KZ1100 A2
  • BSKZ650
  • BSKZ650's Avatar
01 Mar 2010 11:43
#350735
I get a kick out of all the " biodegradable" products, yes they are in the origonal formula, but the second you introduce any oils, solvents, fuel, or anything that you clean with it, the product is NOT "green" friendly anymore,
sorry,, had to vent,,,;)
77 ltd1000, current rider
76 kz900, just waiting
The following user(s) said Thank You: tnpete
  • z1kzonly
  • z1kzonly's Avatar
01 Mar 2010 14:14
#350761
GUNK and GUNK only.
Used it for 30 years.
It smells though!
Want to use it at the street curb or near a drain.
  • Jack
  • Jack's Avatar
01 Mar 2010 14:25 - 01 Mar 2010 14:27
#350765
Go to the Projects Forum and scroll down to 78 KZ 1000 makeover thread and check out his ultra clean cases. Best method I've seen yet - vapour blasting or US spelling vapor blasting.
79 KZ 1075 MKll
79 KZ 1500 MKll dragbike
Gone but not forgotten:
3 X 73 Z1's
1 X 74 Z1A
1 X 75 Z1B
Last edit: 01 Mar 2010 14:27 by Jack.
  • APE Jay
  • APE Jay's Avatar
01 Mar 2010 17:55
#350791
Take the cases to the local transmission shop and have them put them in their washing machine.
  • porchev914
  • porchev914's Avatar
01 Mar 2010 18:52
#350808
I know polkat hasn't said as much, but I have a feeling his engine is still assembled and in the frame. If it's still bolted in then ditto what these guys have said- solvent and elbow grease is the only thing that will do any good on the roughest, grimiest spots :) And like Jack suggested, if you want your cases to look amazing and your engine IS apart, I can direct you to a some guys that'll do it quick, and the total cost (for me) was $105 minus the side covers B)
FRANKEN Z!
  • pburnhamb
  • pburnhamb's Avatar
01 Mar 2010 20:15
#350818
Porhev? so what dd these guys do to yours??? didthey blast it w/ somethin....What? thank you
1978 kz650b (810, 750 head)
1976 kz900
1977 xs650
  • polkat
01 Mar 2010 21:15
#350829
The case is still in the frame, but everything from the block up is on my work bench. As I mentioned, I'm too poor right now to afford some shop work just to clean grime off the parts.
I heard Gunk mentioned again. So you guys think Gunk is safe on aluminum (even though it says right on the lable that it's not)?
