Stator Winding Shielding
- DoubleDub
- Visitor
28 Feb 2010 08:43 - 28 Feb 2010 08:44 #350551
by DoubleDub
Stator Winding Shielding was created by DoubleDub
I had to pop off the stator cover to try and correct a small leak (suprisingly, I don't think it's from the grommet).
However, I noticed that the shielding on one of the wires from the stator was bare for a brief section. Is there any risk of arcing here?
Might be difficult to see, but it's the wire on the bottom that is shielded with the bare wire wound around it. There's just a small section of shielding that appears to be missing.
Last edit: 28 Feb 2010 08:44 by DoubleDub. Reason: spelling, etc.
- otakar
28 Feb 2010 09:19 #350558
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
Replied by otakar on topic Stator Winding Shielding
this would become a problem if the oil gets too dirty or if water gets into the oil or a combination of the two.. If you are nervous about it, just clean it very well to remove the oil and coat it with epoxy or a good urethane varnish.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- DoubleDub
- Visitor
28 Feb 2010 09:57 #350562
by DoubleDub
Replied by DoubleDub on topic Stator Winding Shielding
Perfect - Thanks!
- otakar
28 Feb 2010 09:59 #350563
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Hope to ride with you this summer.
Otto
Otto
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- MFolks
- Thank you received: 540
28 Feb 2010 12:47 #350588
by MFolks
Replied by MFolks on topic Stator Winding Shielding
The local electric motor rebuilding shops should be able to get some of that brush on varnish for you. To speed the drying, use a hair dryer.
Clean the bare area with lacquer thinner first to remove the oil for a good bond.A small clean paint brush followed by a cotton swab dipped in solvent should clean well.
