Compression Test
- kz krazy
26 Feb 2010 20:55 #350329
by kz krazy
1978 KZ 1000A 1976 KZ 900 1980 Z1 Classic
Compression Test was created by kz krazy
Is it possible to do a test on a bike that's not running? I have a 75 Z1 motor that used to run strong,been setting for 10+ years,still turns over with kickstarter,has 31,000 miles on the odometer,don't know if right? Should I try to get bike running again? How long sitting is to long ?
- trianglelaguna
- Thank you received: 235
27 Feb 2010 02:29 #350337
by trianglelaguna
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
Replied by trianglelaguna on topic Compression Test
if it turns over...and there is still an intact bike...then why not try and throw a bettery in and cross your fingers...claen the carbs..change the oil...plugs...and see if it runs.....
1976 KZ900
2003 ZX12R
2007 FZ1000
- JMKZHI
- Thank you received: 48
27 Feb 2010 06:34 #350350
by JMKZHI
Replied by JMKZHI on topic Compression Test
You can test the compression. If the carbs are off the bike, it's a tad easier since you won't have to fiddle w the throttle. Although it turns over, while the plugs are out, I'd probably go ahead & put some lubricant in the holes - a little 3-in-1 oil or something.
Unless someone states otherwise, with the car off & the car keys in your pocket, you can jumper the bike using the car battery (assuming the battery is the correct voltage for your bike). That's how I did mine: carbs off bike, plugs out, jumper cables from truck battery (12V), etc.
- sabell
27 Feb 2010 06:42 #350352
by sabell
'78 KZ1000A2
'79 650SR
Replied by sabell on topic Compression Test
I bought both of my bikes from folks that had let them sit for about 10-12 years. After changing fluids, plugs, points and battery they both fired up without too much of a fight.
'78 KZ1000A2
'79 650SR
- otakar
27 Feb 2010 06:43 #350353
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
Replied by otakar on topic Compression Test
My KZ1300 was sitting outside for 14 years. I took the top end off just because after I drained the oil I found antifreeze in the oil. When I puled the head off I found that everything looked in perfect shape. There was no evidence of any rust anywhere in the bores or anywhere els for that mater. The carburetors were a different story however.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- TeK9iNe
- What did you do!?!
- Thank you received: 28
27 Feb 2010 07:11 #350364
by TeK9iNe
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Replied by TeK9iNe on topic Compression Test
No such thing as sitting too long... just parts that require replacing. :laugh:
You don't have to remove the carbs to perform the compression test if you're not too comfortable for that, but it is a little easier.
Just wedge the throttle wide open and pull all the plugs.
Drain the float bowls on the carbs and disconnect the ignition (anywhere), so the coils arent attempting to fire.
GL.
GL.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- Thank you received: 2098
27 Feb 2010 07:39 - 27 Feb 2010 07:42 #350373
by Patton
Replied by Patton on topic Compression Test
kz krazy wrote:
Yes, and doable with kickstarter.
And 31k is barely broken in.
Would also check valve clearances. Might be the first time ever. :ohmy:
Last edit: 27 Feb 2010 07:42 by Patton.
