1980 KZ750 H
  • rayellis
  • rayellis's Avatar Topic Author
1980 KZ750 H
25 Feb 2010 14:27
#350127
Is the 1980 KZ750E and 1980 KZ750H the same bike? Only the LTD is the KZ750H right :so the engines should be identical? Just wondering I might have a chance at buying one and was making sure I could use the engine parts.
Thank You
  • rstnick
  • rstnick's Avatar
  • Premium Member
  • Premium Member
Re: 1980 KZ750 H
25 Feb 2010 17:43
#350167
You could try comparing part numbers on the kawasaki site, but I'd be guessing they are the same basic engine. May be some cam or carb differences.
This post describes how to find and use the diagrams:
forums.kz650.info/index.php?topic=812.0
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
  • da_wun
  • da_wun's Avatar
Re: 1980 KZ750 H
25 Feb 2010 23:19
#350227
The KZ750E was referred to as the KZ750 Standard, which was the "sportier" one. The KZ750H is the LTD.
Engine/Frame-wise they're the same. Main differences are gas tank capacity (E has a bigger tank) and chassis geometry.
source: KZ750 Service Manual. Was looking at it a couple of days ago.
Bare Metal 1980 KZ750H (no longer burgundy)
West-Island, Montreal
  • RonKZ650
  • RonKZ650's Avatar
Re: 1980 KZ750 H
26 Feb 2010 06:41
#350251
The parts are close to the same. In typical kawasaki tradition if you compare the two models you'll find there are a lot of different part numbers. The cylinder, head ect carries a different part number. Probably mainly color differences and minor stuff like that. For sure the frames are different. A LTD frame has all different mount points for the bodywork ect. If you look at Kawasaki parts for the most part every frame is different. Even a 1980 KZ750E is different from a 1981. 1980 KZ750H is different and 1981 KZ750H is another change. Every one is made only one/two years at most and never the same frame used on a different model designation.
  • cafekz750
  • cafekz750's Avatar
Re: 1980 KZ750 H
26 Feb 2010 11:02
#350286
Ron is right regarding the part numbers.
However, you are probably in luck as I have a 1980 KZ750E engine in my 1981 KZ750H frame currently for the fun it. The engines are the same except for the black paint on the KZ750E engine.
1981 KZ750H2 - V&H 4-1 pipe, pods, jetted, clubmans, homebrew rearsets, 18" rear wheel and more.
Parting out a 1982 KZ750H3 to fund future projects
2 other non-Kawasaki motorcycles
  • JMKZHI
  • JMKZHI's Avatar
Re: 1980 KZ750 H
26 Feb 2010 13:16
#350298
He indicated that he's looking to use engine parts, which may not be quite the same thing as simply swapping engines between frames.
