- Thank you received: 3
water problem
- cobura
- forever 2 wheels
25 Feb 2010 07:43 #350054
by cobura
1979 KZ650B3
water problem was created by cobura
just gonna throw this question out, its kind of a weird problem i think.
Does anyone know how to get water out of the top-end of an engine that doesn't have a kick starter and starter motor is bad??? Carbs are taken off and i can visibly see water sitting in each of the 4 intakes.
1979 KZ650B3
- chance
- Life long biker/
25 Feb 2010 08:02 - 25 Feb 2010 08:11 #350057
by chance
Replied by chance on topic water problem
Push it without plugs in a higher gear and look out..
or turn it over from the crank with a 17mm wrench...
Last edit: 25 Feb 2010 08:11 by chance.
- MDZ1rider
- Thank you received: 118
25 Feb 2010 09:28 #350078
by MDZ1rider
Replied by MDZ1rider on topic water problem
WITH THE PLUGS REMOVED! If you can see water in all 4 intake ports, you've got to assume at least some of cylinders are full as well. It's going to run into any cylinder on an intake stroke. Water does not compress like air. If you force that motor to turn, the cylinder on the compression stroke will have no choice but to bend or break something expensive.
Actually I'd try suctioning as much water as possible with a piece of tubing down the plug hole before attempting to turn it over.
I've got to ask...How did this happen?
- MFolks
- Thank you received: 540
25 Feb 2010 14:49 #350131
by MFolks
Replied by MFolks on topic water problem
I'd use a vacuum that will extract water(shop vac is one) and then spray some PB Blaster where the water was to reduce corrosion.
- pburnhamb
- Thank you received: 2
25 Feb 2010 14:57 #350134
by pburnhamb
1978 kz650b (810, 750 head)
1976 kz900
1977 xs650
Replied by pburnhamb on topic water problem
If I were Me, i'd take the head right off. i gotta know too......how'd water get in there?
and you're sure its water, not gas....
i would also change the oil at least twice in close intervals once she is up and at-em again.
1976 kz900
1977 xs650
- trianglelaguna
- Thank you received: 235
25 Feb 2010 15:07 #350135
by trianglelaguna
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
Replied by trianglelaguna on topic water problem
blow it out with a compressor and a nipple blower....rigg up a suction tube with some duct tape to a vacum hose???
turn the frame upside down for a half hour????2 minutes???
then blow dry ...and pb blast or marvel mystery oil ect...wd-40.....
how did it happen...............please:huh:
1976 KZ900
2003 ZX12R
2007 FZ1000
- cobura
- forever 2 wheels
26 Feb 2010 05:19 #350244
by cobura
1979 KZ650B3
Replied by cobura on topic water problem
sorry i've been busy and couldn't reply sooner. The bike in question is my new suzuki katana 250. I bought it from my friend who owns a junkyard for about $100. I knew it wasn't working but thats all i knew. When i got it home I decided to tear into it, and the first thing that i noticed was that the airbox was almost full to the brim with dark brown water. I was shocked because most bikes i have worked on have a drain at the bottom of the airbox to prevent this from happening. I then realized that for some dumbass reason, suzuki thought it would be good to put a stopper in the bottom of the hose that drains the airbox. I pulled the stopper and about a half gallon of that brown juice came out. It was definitely just water and rust, not gas or oil. I then realized that the water had eaten away at the carburetor as well and that it was probably completely shot. I pulled the carburetor off and realized that the water had also made its way to the engine. I'm not sure if the water has been in there for a long time or if it just got in there since i started playing with it.
What is this "pb blast"?
1979 KZ650B3
- DoubleDub
- Visitor
26 Feb 2010 05:57 #350246
by DoubleDub
Replied by DoubleDub on topic water problem
A brand of penetrating oil that is highly reviewed.
- Bluemeanie
- Thank you received: 14
26 Feb 2010 06:22 - 26 Feb 2010 06:22 #350248
by Bluemeanie
Replied by Bluemeanie on topic water problem
cobura wrote:
One of the best penetrating oils on the market. Available just about anywere. Keep a can in the garage.
Last edit: 26 Feb 2010 06:22 by Bluemeanie.
- keith1
26 Feb 2010 07:05 #350254
by keith1
Replied by keith1 on topic water problem
