Shims marked "A"
  • ironpan65
  • ironpan65's Avatar Topic Author
  • *UNTOLD*
Shims marked "A"
23 Feb 2010 22:43 - 23 Feb 2010 22:46
#349888
Moving shims around (900 engine)...I noticed the "A" mark on some of them
Just curious if this is supposed to mean anything:huh: ?
UNTOLD
Last edit: 23 Feb 2010 22:46 by ironpan65.
  • roy-b-boy-b
  • roy-b-boy-b's Avatar
Re: Shims marked "A"
24 Feb 2010 04:11
#349898
I believe thise are the ones prone to shattering. Roy
  • BSKZ650
  • BSKZ650's Avatar
24 Feb 2010 06:22
#349908
thought the A was half size,, but I will need to go to the shop and measure mine to see
77 ltd1000, current rider
76 kz900, just waiting
  • RonKZ650
  • RonKZ650's Avatar
24 Feb 2010 06:28
#349909
No difference.
  • otakar
  • otakar's Avatar
Re: Shims marked
24 Feb 2010 07:04
#349913
RonKZ650 wrote:
No difference.
+1 I concur.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
Re: Shims marked
24 Feb 2010 07:13
#349916
otakar wrote:
RonKZ650 wrote:
No difference.
+1 I concur.
I've measured both (within a size) and there is no difference.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • JakeB
  • JakeB's Avatar
24 Feb 2010 07:24
#349917
I just pulled my shims out last night, I have a couple with the 'A' and one that has a 'Y' in front of the number. :huh:
Don't the shims that were prone to breaking have a dimple in them? The 'A' shims that I have don't have any dimples in them.
1978 Z1-R
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
Re: Shims marked
24 Feb 2010 07:35
#349921
Y = Yamaha, but will work...Jeff Saunders also mentioned that Ford SHO shims are also 29mm.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
24 Feb 2010 09:23 - 24 Feb 2010 09:27
#349935
As Roy says, I too have heard that dimpled shims were prone to shattering. And the lower shim in the above posted photo appears to have a dimple.
The FSMs don't seem to mention the dimple issue with either shims or tappets. :unsure:
My understanding from the 1974 Chilton's Kawasaki 900Z1 manual is that the original tappets (aka buckets) with navel (aka dimple) in tappet/shim mating area (P#12032-004 used up to engine #Z1E-08979) sometimes caused shim fracture, and were replaced with new design tappet P#12032-005, with recommendation to replace all old style tappets and also replace shims used with the old style because the shim may have begun to fracture.
But Chilton doesn't mention dimpled shims. :S
Hoping someone will better clarify this dimple business. Meanwhile, I would avoid shim or bucket with dimple.
Good Luck! :)
Last edit: 24 Feb 2010 09:27 by Patton.
