- Thank you received: 1
750-4 valve seals?
- polkat
23 Feb 2010 18:48 #349861
by polkat
750-4 valve seals? was created by polkat
Who has the best price on 750-four valve seals, and will any non-Kawasaki seals fit? Thanks!
- otakar
23 Feb 2010 18:54 #349862
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
Replied by otakar on topic 750-4 valve seals?
7mm valve seals are almost universal. just make sure that you get Viton seals. They are green in color and will outlast OEM seals 10:1 I get mine fro Joe Hooper at Pit Stop Performance In Orlando FL. He gives me very good prices I believe that Jeff at ZIE also has them for a very good price.
Joe Hooper
3213 Paisley Circle
Orlando, Florida 32817
joehooper@cfl.rr.com
407-679-9116
Joe Hooper
3213 Paisley Circle
407-679-9116
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- otakar
23 Feb 2010 19:00 #349864
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- polkat
23 Feb 2010 19:07 #349867
by polkat
Replied by polkat on topic 750-4 valve seals?
Do you know the Viton part number for the 750-fours?
- otakar
23 Feb 2010 19:12 - 23 Feb 2010 19:15 #349868
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
As I mentioned, they are the same for all the Kawasakis 550, 650, 700, 750-4, 900, 1000, 1100, 1300 and so on. Anything that has a 7mm valve stem. I noticed that Z1E only has the OE ones.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 23 Feb 2010 19:15 by otakar.
- bountyhunter
- Thank you received: 337
23 Feb 2010 19:14 - 23 Feb 2010 19:15 #349869
by bountyhunter
Replied by bountyhunter on topic 750-4 valve seals?
Lucky bugger. Every engine except the 750 twins had those valve seals......
Second on Viton seals, they are way better than rubber. Viton is the cat's pajamas.
Last edit: 23 Feb 2010 19:15 by bountyhunter.
- polkat
23 Feb 2010 19:19 - 23 Feb 2010 19:20 #349871
by polkat
I want to get them locally, but the guys here want a Viton part number. Someone here told me that it's VS-454. Does that sound right?
Last edit: 23 Feb 2010 19:20 by polkat.
- otakar
23 Feb 2010 19:23 #349873
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Couldn't tell you do not know.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
