Can't get it to start
- emaxxima
23 Feb 2010 15:52 #349830
by emaxxima
1979 Kawasaki KZ650
Vernon Hills, IL
Can't get it to start was created by emaxxima
Just cleaned all the carbs and replaced the coils. Plugs are getting a good spark but still can't get the bike to run. Only one cylinder is firing, the far right one. I tried tweaking with the carbs but its still only firing one cylinder. Where should I go next? I read something about setting points, would that prevent the bike from starting?
1979 Kawasaki KZ650
Vernon Hills, IL
- bountyhunter
- Thank you received: 337
23 Feb 2010 16:12 - 23 Feb 2010 16:13 #349832
by bountyhunter
Replied by bountyhunter on topic Can't get it to start
Check compression on all cylinders.
Check all spark plugs for spark.
Check plug condition to see if wet with fuel or dry.
Make sure you didn't reverse the points wires going to the coils.
Check points gap.
Check static timing.
Check points gap.
Last edit: 23 Feb 2010 16:13 by bountyhunter.
- TeK9iNe
- What did you do!?!
- Thank you received: 28
23 Feb 2010 16:25 - 23 Feb 2010 16:25 #349836
by TeK9iNe
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Replied by TeK9iNe on topic Can't get it to start
bountyhunter wrote:
2 Thumbs up.
+ Shim to cam gaps (valve lash).
+ Air filter properly installed! (a must!) and everything air tight from the airbox snorkel tip to the exhaust end tip! MUST be airtight everywhere.
GL my friend.
Check compression on ALL cylinders.
Throttle wide open/all plugs out/carb bowls drained when checking compression!
Check ALL spark plugs for spark.
Check points gap.
2 Thumbs up.
GL my friend.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Last edit: 23 Feb 2010 16:25 by TeK9iNe.
- Thank you received: 2829
23 Feb 2010 16:36 #349837
by 650ed
Replied by 650ed on topic Can't get it to start
emaxxima, we need more information. Specifically, a little history on the bike. When is the last time you had it running? Was it running before you cleaned all the carbs and replaced the coils? Ed
- anarki650
- Thank you received: 5
23 Feb 2010 17:21 #349848
by anarki650
09 Kawasaki ER6n
77 kz650b1 cafe rebirth project
"Being shot out of a cannon will always be better than being squeezed out of a tube, that's why God made fast motorcycles..."
Dr. Hunter S. Thompson
Omaha NE
Replied by anarki650 on topic Can't get it to start
Bountyhunter and TeK9iNe have it right. Start by verifying good compression, then move to valve clearances.
Once you know both of these are in spec thoroughly clean the carbs, using compressed air to blow out all the passages after cleaning, check float heights, replace jets with new and get carbs bench synced. Check the condition of the carb holders and intake boots to make sure no leaks are occurring.
Now make sure your timing is dead spot on. Static timing will get you close, but you really need to use an inductive light to make sure it's dead spot on.
Now verify you're getting 12v to the coils and the charging system is up to snuff and you're problem free riding!
I've used this checklist with every bike I've ever brought back from the dead and it's really the only way to get things right. If you have shitty compression or out of spec valves you might think you have carb issues even with perfectly dialed in carbs.
Good luck!!!
Good luck!!!
09 Kawasaki ER6n
Omaha NE
- Russ Jackson
- Thank you received: 1
23 Feb 2010 17:40 #349852
by Russ Jackson
1976 KZ 900 B1 29 smoothbores, Kerker, Lester Mags
2008 Kawasaki Concours 14 abs
Replied by Russ Jackson on topic Can't get it to start
Check for spark, are the plugs wet or fouled? One is firing are the plug wires correct? Did it run before? Put the carbs back to stock settings and start over. How did you clean the carbs and what shape were they in? Did you take them down all the way?...Russ
- KZCool
24 Feb 2010 13:52 #349959
by KZCool
1976 KZ750 hardtail
Replied by KZCool on topic Can't get it to start
Once when I cleaned my carbs and put them back on I had the same problem. Worked fine before then nothing. After a bit of tinkering, I took them back off and I had put the main jet needle in after the plastic peice that goes above it. So the needle just popped out of the carb where it should have been and was stuck up with the spring. Big GOOF on my part
1976 KZ750 hardtail
