81 750 ltd
- romy624
- Visitor
23 Feb 2010 14:11 #349827
by romy624
81 750 ltd was created by romy624
good compression in all but number 2 cyclinder im thinking broken ring? could it be a bent or stuck valve?
- wrangler615
23 Feb 2010 14:15 #349828
by wrangler615
83 Kaw KZ750F1 - massive money pit
82 Zuki GS1100G - my daily driver, possible sacrilege I know
Replied by wrangler615 on topic 81 750 ltd
You need to do a leak down test to see where to go. Cylinder at TDC, feed air pressure into the spark plug hole. Check where you hear air leaking out.
From carb = intake valve issue
From tailpipe = exhaust valve issue
From oil fill hole = ring issue
If either valve issue, make sure to check and double check valve clearance first. Go from there!
HTH, Justin
HTH, Justin
- romy624
- Visitor
23 Feb 2010 20:10 #349879
by romy624
Replied by romy624 on topic 81 750 ltd
thanks justin ill do that
