- Thank you received: 540
Need a spec. for Z1 KZ 900 motor spacer
- z1kzonly
21 Feb 2010 15:17 #349504
by z1kzonly
Need a spec. for Z1 KZ 900 motor spacer was created by z1kzonly
Hi, I seemed to can't find one after all the parts I had.
I need the lenght of the rear motor mount spacer on the left hand side of a Z1-KZ900 engine.
The round spacer right above the rear brake pedal.
The one the that the carb drain holder rubber wraps around.
I will make one out of aluminum. I just need the correct lenght. Should be about an inch and a half approx.
Thanks in advance.
Marty in Buffalo
Thanks in advance.
Marty in Buffalo
- Sandy
- Fly High,Tony
- Thank you received: 13
21 Feb 2010 15:35 - 21 Feb 2010 15:37 #349508
by Sandy
1977 KZ1000 A-1
Replied by Sandy on topic Need a spec. for Z1 KZ 900 motor spacer
Using digital calipers...32.04mm
1 and a quarter inch bang on.
1977 KZ1000 A-1
Last edit: 21 Feb 2010 15:37 by Sandy.
- PLUMMEN
- Thank you received: 104
21 Feb 2010 16:00 #349520
by PLUMMEN
Replied by PLUMMEN on topic Need a spec. for Z1 KZ 900 motor spacer
thats 1 3/16" on the american version according to my tape measure
- Sandy
- Fly High,Tony
- PLUMMEN
21 Feb 2010 16:40 #349540
by PLUMMEN
it happens! :woohoo:
- z1kzonly
21 Feb 2010 18:15 #349554
by z1kzonly
Replied by z1kzonly on topic Need a spec. for Z1 KZ 900 motor spacer
Thanks Sandy. I'll take the 32.04mm and convert to thousands of an inch.
Thank You.
Thank You.
- PLUMMEN
21 Feb 2010 18:21 #349555
by PLUMMEN
but mine really is 1 3/16"
- z1kzonly
21 Feb 2010 18:21 #349556
by z1kzonly
1.261 inch, this works for me.
Thanks
Thanks
- Sandy
- Fly High,Tony
21 Feb 2010 20:22 #349577
by Sandy
1977 KZ1000 A-1
Plumjuice,I was NOT drinking when I measured it,lol.
1977 KZ1000 A-1
