After 7 years its alive!, mostly..
- KLD
Heres some pictures
Thats what the first sparkplug looked like after running it for about 5 minutes with full choke. The rest of the spark plugs looked the same as the second one
- Thank you received: 2098
If not already done, would attach brand new NGKB8ES spark plug to plug wire, ground plug base to engine head, spin engine over and visually inspect spark quality at tip of plug.
If spark looks okay, install the brand new NGKB8ES spark plug and again test run engine.
If #1 cylinder still fails to combust, would perform compression test on #1 cylinder. AND assure both valve clearances are to specs in #1 cylinder. A too tight valve could easily cause the reported problem (even where cold compression test seems okay).
When satisfied that both spark and compression and valve clearances are okay in #1 cylinder, would then perform clear tube test to assure fuel level in float bowl isn't too high and causing a too rich condition in #1 carb.
Given good properly timed spark with decent compression and correct valve clearances, and prescribed fuel level, if combustion still fails in #1 cylinder, the problem is probably carb related. Most likely an issue with the pilot circuit (or maybe the enrichener circuit) in #1 carb.
Pilot circuit passages, both air passage and fuel passage and air-fuel passages, are sometimes very difficult to clean. And sometimes the pilot jet is so dirty or damaged that it should be replaced with a new pilot jet of the same size.
Would also assure intake air filter isn't over-oiled or otherwise blocked. Some pod models may partially obstruct the pilot air intake hole. Could remove the pod on #1 carb for test run.
Good Luck!
- Kawickrice
- Thank you received: 18
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
- TeK9iNe
- What did you do!?!
- Thank you received: 28
I may just cut n' paste this to several other locations! :laugh: :laugh: :laugh:
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- Thank you received: 797
does the #1 plug have gas on it?
- KLD
- z650c3
No, It did not smell of gas at all
Sounds like almost certain to be a carb problem Best of luck gettin it sorted.
Cheers
c3
1979 z650 c3 first registered in 1981
2006 Harley Davidson VRSCR
Northern Ireland
- KLD
Did a quick compression test and it was good. It has good spark. It doesn't have any type of filter on at the moment to restrict air flow. Valve clearances are up to spec. The jets are clean as a whistle. So.. that leaves the fuel passages.. i suppose
[Click on image to enlarge view.]
Good Luck!
- KLD
- Old Man Rock
- Thank you received: 225
See if the problem follows to #4 then it's electrical and not carbies....
Just a thought before having to tear apart the carbs...
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
I pulled the carbs off and the float level was too low, so I readjusted it....
Would more likely suspect a too high fuel level causing the black sooty plug from an over rich mixture.
Am hoping the clear tube test was performed.
When performing the clear tube test to determine float bowl fuel level, pulling the carbs isn't necessary. Because the clear tube test may be performed with the carbs remaining installed on fully assembled bike, without carb removal or disassembly. Bike should be held level and stationary during the test.
The clear tube test tells the true actual existing fuel level, regardless of float buoyancy and other variables.
Imo, the carb-disassembled-upside-down-on-workbench method (measuring physical distances involved) is a ball park adjustment to be confirmed with the clear tube test.
The clear tube test may also be performed with the assembled carbs on the workbench. Where the carbs must remain level during the test.
Too high fuel level in otherwise perfect carbs, and perfect everything else, will cause over rich mixture evidenced by black sooty plugs.
Good Luck!
