Header difference 1000 LTD verses KZ1000
- Z1Class005
16 Feb 2010 16:27 #348683
by Z1Class005
Header difference 1000 LTD verses KZ1000 was created by Z1Class005
Why won't a vance and hines header for a 1000 LTD fit a KZ 1000? Would it fit if you added a strap between header mount bolt hole to hole on rear suspension location? thx dew
- roy-b-boy-b
- Thank you received: 103
16 Feb 2010 17:28 #348699
by roy-b-boy-b
Replied by roy-b-boy-b on topic Header difference 1000 LTD verses KZ1000
All I would think that would be diffrent is the position of the passenger pegs. Roy
- PLUMMEN
- Thank you received: 104
16 Feb 2010 17:53 #348706
by PLUMMEN
Replied by PLUMMEN on topic Header difference 1000 LTD verses KZ1000
all the headers ive ever used had a mounting strap that came off footpeg bracket
- Thank you received: 2098
16 Feb 2010 18:22 #348711
by Patton
Replied by Patton on topic Header difference 1000 LTD verses KZ1000
Have always enjoyed using a mini-motor mount in the connection to isolate the frame from exhaust vibration.
Good Luck!
Good Luck!
